Canyon Ultimate CF SLX 2017 / Dura-Ace / SRAM eTap / Zipp 202
dorin wrote:Racer7 wrote:Yes one question hahaha how do you close the holes? [emoji14]
hi there, are you referring to the unused holes due to eTap? Canyon offered grommets to close the unused "ports"
Cheers,
Dorin
were they included along with the bike or you bought them separately?
quality carbon repairs and paintjobs @bikebay.lv
https://www.instagram.com/bikebay.lv/
aspms wrote:dorin wrote:Racer7 wrote:Yes one question hahaha how do you close the holes?
Cheers,
Dorin
i got them for free
i wanted the stealth red color and was planning to use Di2 but then they told me will not work due to the internal routing, eTap came then into question and they suggested to use the grommets. Before then i ordered a pair of grommets from Cannondale, will let you know if they fit on the frame next week once the frame arrives and i start putting it together.
Cheers
Pls more infos about the grommets. I used the grommets which come with the frame, so there are some little holes left (where the DI2 cables go through). Canyon told me that there are NO specific grommets for the eTap bikes.
Bought some grommets online but they are too bright for the grey frame and very big. So I'm not that satisfied with them.
See my CF SLX in the signature.
cnyn wrote:Pls more infos about the grommets. I used the grommets which come with the frame, so there are some little holes left (where the DI2 cables go through). Canyon told me that there are NO specific grommets for the eTap bikes.
i cant find on the iphone the order details, i'll search from home, or send you the part number as soon as they arrive
Yes that would be interesting
& I'm from Switzerland too
Weil ich neugierig war, habe ich gleich mal den Canyon Chat bemüht:
Es gibt also wohl spezielle eTap-Rahmen ohne Löcher und es gibt keine "offiziellen" Canyon Stopfen.... Hmmm
Wie kann ich Dir helfen?
ich: Hallo. Gibt es für die Ultimate CF SLX Rahmen, welche mit eTap montiert werden, spezielle Stopfen für die übrig geblieben Löcher um diese zu verschließen?
Ich habe ein Ultimate mit eTap selbst aufgebaut und natürlich jetzt Löcher im Rahmen. Ich habe gehört es soll solche Stopfen wohl von Canyon geben?
Just a moment...
Support Alina: Guten Morgen :slightly_smiling_face:
Leider nicht, wir haben nur die "originalen" Stopfen. Allerdings gibt es ein paar andere Wege, wie du diese Löcher verschließen kannst. ZB mit Silikonmasse oder (je nach dem wie viele Löcher es sind) kannst du sie auf offen lassen. Wenn das Bike mal nass werden sollte zB durch Regen hat das Bike auf Revisionsöffnungen, aus denen das Wasser wieder austreten kann
ich: Originalen heißt die, für die DI2 Montage?
Support Alina: Genau richtig
ich: Hm okay danke für die Information. Gibt es da Unterschiede vom Canyon Standort her? Deutschland/Schweiz etc.?
Also könnte es sein, dass es andernorts doch etwas gibt?
Ich persönlich mag den Rahmen nicht so offen lassen muss ich ehrlich gestehen.
Support Alina: Nein, da gibt es ortsbezogen keine Unterschiede. Wir haben solche Stopfen generell nicht produziert.
ich: Wie montieren Sie denn Ihre eTap Räder? Bleiben die Löcher da einfach offen?
Support Alina: Das kann ich verstehen, würde dann über die Variante mit dem Silikon nachdenken an deine Stelle :slightly_smiling_face: Wenn du da durchsichtig trocknendes nimmst und die Löcher sauber füllst und abschließt, fällt das so gut wie garnicht auf, habe ich schon öfter gesehen :slightly_smiling_face: Das sind andere Rahmen bzw. besser gesagt anders vorbereite Rahmen
ich: Achso, die haben gar keine Öffnungen?
Support Alina: Genau, die haben nur die benötigten Öffnungen :slightly_smiling_face:
ich: Ah okay, danke.
Support Alina: Sehr gern! Kann ich dir sonst noch weiterhelfen?
ich: Nein, das wars schon, vielen Dank.
Schönen Tag, schöne Weihnachten und einen guten Rutsch
Support Alina: Danke dir! Das wünsche ich dir und deinen Lieben auch! :slightly_smiling_face: Bis bald
cnyn wrote:Weil ich neugierig war, habe ich gleich mal den Canyon Chat bemüht:Wie kann ich Dir helfen?
Just a moment...
I've also asked in the chat and they gave me the same answer, and the supporter was Alina too :')
But I'm not sure if Katusha has other frames for the use with the eTap, look at this article with the pictures: http://www.cyclingweekly.co.uk/news/pro ... 016-202699
cnyn wrote::D
Well this article is from 2015, so maybe they changed sth?
Would be interesting to see some pics of the 2017 team bikes.
This is the only picture I've found. You can see that there are some grommets on Pavel's bike...
