It is currently Mon Jan 22, 2018 11:40 pm
Post new topic  Reply to topic  [ 44 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Fri Dec 30, 2016 4:44 am
plpete wrote:
would definitely use some recommendations on light butyl tubes.
Continental race 28 light are about 150 a set. From what I've read much lighter than that and you might as well use latex.
Sent from my SAMSUNG-SM-G935A using Tapatalk
My Strava Profile
2016 Cannondale CAAD12
PostPosted: Mon Jan 02, 2017 7:38 pm
I've had fantastic luck over the last five or six year with continental super sonic tubes. Much better luck than I've had with latex, easy to patch on the road
PostPosted: Wed Jan 04, 2017 1:18 pm
Bike is almost finished. The only things I still need are a stem and a Stages powermeter arm. Going with Stages as it will be light, allow me to keep the crank, which I like very much for its looks and weight, and it's all I really need to racing. Not like I'll be looking at my numbers the whole time while racing :lol: I have a Quarq Elsa on my BMC SLR01 that I can always use as well. Did three days of solid riding so far and loving the bike. I know this sounds hard to believe but with the set up below the bike felt as comfortable as my carbon bike. It really rides that smooth. Might be too smooth for some. You still feel the bigger bumps and it's not plush by any means but I feel comfortable doing 100mi on it. With the stock 100mm stem and no PM yet the bike comes in exactly at 6.8kg
My Bikes:
BMC SLR01 TeamMachine
Cannondale CAAD8
PostPosted: Wed Jan 04, 2017 3:14 pm
Looks awesome.
I'm mid build with mine as I type. Just put 44g skewers, DA9000 mechs, KMC-SL11 chain and DA 11-25T cassette on it.
Mines the disc model but looking to buy the same wheels as you (disc version). How are you finding them?
Had my C2 stem off last week too, 108g with bolts. Bloody light but only 100mm.
Also, where did you get your bearing cap from? Wanna slam my stem too.
'16 Cervelo S5 - 6900g
'17 Focus Mares Force 1
'15 Scott Addict Team - 6850g Sold
'17 Cervelo R3D DA - 7580g - Sold
'16 Cannondale CAAD12 DA Disc - 7560g - RIP
PostPosted: Fri Jan 06, 2017 2:13 pm
ryanw wrote:
Looks awesome.
What's your Dura-ace disc version weighing in at?
I'm considering the Ultegra version, which is currently £1449 at Leisure Lakes...
PostPosted: Fri Jan 06, 2017 2:35 pm
markgoldstein wrote:
ryanw wrote:
Looks awesome.
At present it's 8kg on the nose with pedals, cages, mounts (ready to ride). That's with the standard Mavic wheels (2045g).
Just picked up a pair of Mavic Krysium Pro SL C Discs which will drop the weight down to 7.5kg.
Aim is to be around 7kg once complete.
It's my daily commuter so needs to be robust and practical.
PostPosted: Mon Jan 23, 2017 8:20 am
Not much progress in my CAAD12 project lately. Still waiting for some parts to arrive, at the moment also do not have much time to use for building.
While waiting for other parts, decided to tune an old Arx Team stem to better match the new frame colors.
The stem is most likely just a temporary solution. I think it is a bit too long for this bike, but I will still start with it. Did the similar tuning for an Ergosum Pro handlebar also: removed the white arc from the left side of the bar.
PostPosted: Sat Feb 04, 2017 6:47 pm
Today had some spare time and decided to install the bottom bracket and the cranks to the frame.
The installation of the wishbone bb was very smooth. Before installation I lightly greased the bb shell, then just screwed in the halves of the bottom bracket. Finished by tightening them with the two bb tools that came with the bracket. The painted finish of the wishbone bb seems to be of good quality, the tools did not leave any marks to the surface.
Installing the fulcrum cranks required some more effort. The ultra torque bearings were very tight fit to the bb and it took me quite a long time to slide them into the bb so deep that I was then able to finish installation with the connecting screw. The result was good and the cranks are now spinning smoothly in the bottom bracket.
I had earlier tested the fit of the crank bearings to the bottom bracket and I knew that the tolerances are very small. If the crank bearing is not pushed into the bb in the perfect angle, it will not go in without force; but if the angle is correct, it just slides in. I just hope I did not cause any damage to the bb when wrestling with it today. :D
During the previous weeks I already had installed the stem and bar (3T arx team, ergosum pro), the seat post and the saddle (cannondale save, flite), the brakes and shifters (chorus) and most of the cables. The bike looks already much better than the bare frame. The current weight is under 4 kgs. :D
PostPosted: Sat Feb 04, 2017 7:27 pm
Theres no much drop on that one... 5-7cm? I understand you slem the stam :)
Nice bike!
PostPosted: Sun Feb 12, 2017 3:46 pm
Some progress with my CAAD12: installed the front and rear derailleurs, connected the cables and installed the chain. I was also now able to check the weight of the bike: it seems the weight of the finalized bike will be somewhere around 7.1-7.2 kgs without pedals. Not super light, but then again, I have not selected any component of the bike because of the weight.
PostPosted: Sun Feb 12, 2017 3:51 pm
@kervelo: You should make a separate thread for your bike. I'm interested to see where there is such a big difference in weight. Mine Is down to 7.6kg from 8.3kg, but I'm starting to run out if ideas with out spending ridiculous amounts of money.
My Strava Profile
PostPosted: Sun Feb 12, 2017 4:43 pm
@evan326: let's see, perhaps I will do that.
It is possible that I have estimated the target weight incorrectly somehow. For example, I checked the weight with different wheels than the ones I will use eventually. The weight of the wheels should be approximately the same, though. As most of the parts have been installed to the frame already, the weight is quite easy to estimate.
PostPosted: Sun Feb 12, 2017 4:49 pm
I've been logging info on each part I takeoff and research. I've got a pretty cluttered spreadsheet looking at different setup options.
Here is where I am now https://docs.google.com/spreadsheets/d/ ... sp=sharing
My Strava Profile
PostPosted: Sun Feb 12, 2017 9:56 pm
#boycottspecialized
White Power Saddle.
PostPosted: Sun Feb 12, 2017 9:58 pm
I had mine down to 7560g w/ pedals, cages & mount from 8510g without pedals, cages and mount.
Unfortunately it got written off last Wednesday when I got hit by a taxi.
Now sitting at home in a sling and a leg brace (f**ked MCL, broken radial head and medial head of femur)...
There are no new unread posts for this topic. Caad12 Black Inc. Build
[ Go to page: 1 2 3 4 5 ]
raffit78
72
18665
Tue Jun 06, 2017 4:38 am
raffit78 View the latest post
There are no new unread posts for this topic. Introduce my caad12 black inc - 5.89kg (12.98lbs) cannondale
jinnie799
36
5862
Tue Sep 26, 2017 7:20 pm
Mep View the latest post
There are no new unread posts for this topic. Caad12 help
raffit78
Thu Jun 01, 2017 3:00 am
are View the latest post
There are no new unread posts for this topic. New Caad12 build
Hapsmo911
20
2457
Tue Oct 31, 2017 12:13 am
Hapsmo911 View the latest post
There are no new unread posts for this topic. CAAD12 headset
tomee
Fri Feb 03, 2017 1:58 am
tomee View the latest post
Users browsing this forum: coriordan, Everyone and 21 guests
