Burls Ti Dura-Ace Di2
Here are few shots of my Ti build.
I decided to go custom as I couldn't find a frame with internally routed di2 and rim brakes. I wanted a traditional horizontal top tube with a fairly racy geometry. I read a few reviews and decided to message Justin Burls to get what I wanted. He did not disappoint!
I've not weighted much as I was so keen to get her built and ridden before the roads get salted. It was not meant to be super light but I'm sure we'll look to shed a few grams over time! I'd imagine she'll be weighing in around the 7.5-8kg mark so plenty of room for improvement!
I can't quite decide whether to replace the Zipp decals for black but we'll see!
Here's the spec..
Frame - Burls Ti Custom (54ish)
Fork - Columbus Fel
Headset - Chris King Inset 7
Seatpost Clamp - Burls Ti
Seatpost - Deda Superleggero RS Seatpost 31.6
Seat - Speacialized Power Pro
Stem - Deda Superleggero 100mm
Bar - Deda Superleggero Bar 40cm
Bartape - Fizik Performance Tacky Handlebar Tape
Bottle Cages and hardware - 2x 3k Carbon (Ebay Special)
Outer Cables - Shimano Dura-Ace
Inner Cables - Shimano Dura-Ace
Brakes - Shimano Dura-Ace 9000
Front derailleur - Shimano Dura-Ace 9070
Rear derailleur - Shimano Dura-Ace 9070
Crankset - Shimano Dura-Ace 9000 172.5mm
Bottom Bracket - Shimano Dura-Ace 9000
Chainrings- Shimano Dura-Ace 9000 50/34
Chain - Shimano Dura-Ace 9000
Shifters - Shimano Dura-Ace 9070
Cassette - Shimano Dura-Ace 9000 11-28
Wheels - Zipp 303's
Tyres - Vittoria Corsa CX Open Clincher Road Tyre 700 x 23c
Pedals - Bepro S
Garmin 520
K-Edge Garmin Mount
K-Edge Chain Catcher
Here's the spec..
Fork - Columbus Fel
Wheels - Zipp 303's
Pedals - Bepro S
Garmin 520
K-Edge Garmin Mount
Great looking build!
Justin is a real pleasure to deal with I'd have to agree.
I'd have to say go for the black decals on the wheels but then I am biased.
Not a fan of Zipp but nicely done!
Colnago C-59 (Dura Ace)
Firefly(Ultegra)
Colnago C-64 disc(ultegra) with Bora 35 wheels
Firefly(Ultegra)
Just back from my first ride today (20miles only), it was hovering around 1 degree so probably not the best time to ride but it had to be done. I have to say the ride wasn't what i was expecting, in a good way. The ride was very smooth. The titanium certainly dampens the road vibration a lot more than i was expecting. I was running 23 tyres at 100 psi and it felt so smooth i could hardly believe it. I done a few small climbs and there was hardly any flex at all. I did feel a little heavier than my Supersix but that maybe down to a lack of riding and the cold. I can't really fault it to be honest.
So far so good!
Do you think I should remove the Deda & Zipp decals and go more stealth?
So far so good!
I was amazed by the difference between Ti and Carbon as well. My Burls is so much more comfortable than my Canyon, in fact I've not ridden my Canyon once since I built the Burls. The only time I've actually noticed the difference in stiffness between the two is during heavy sprints. I'd keep the Deda decals just switch the Zipp decals to black.
- jekyll man
Maybe its an optical illusion but the angles look pretty slack?
Its a nice clean build
Official cafe stop tester
phillyt1988 wrote:I was amazed by the difference between Ti and Carbon as well. My Burls is so much more comfortable than my Canyon, in fact I've not ridden my Canyon once since I built the Burls. The only time I've actually noticed the difference in stiffness between the two is during heavy sprints. I'd keep the Deda decals just switch the Zipp decals to black.
I think the Supersix will be banished to the turbo. Maybe I'll buy a Burls Steel for the winter and just ride the Ti in the Summer. Black Zipp Decals Ordered!
Yeah, the difference between Ti and Carbon amazed me also. My only little niggle with the Burls frame is, I wish they were butted tubes to get the weight down a little. The frame's compared to other brands aren't overly light.
What diameter is your seatpost clamp out of curiosity?
Mine's 28.6mm and I'm struggling to find a ti clamp that'll fit.
Point wrote:Yeah, the difference between Ti and Carbon amazed me also. My only little niggle with the Burls frame is, I wish they were butted tubes to get the weight down a little. The frame's compared to other brands aren't overly light.
It is a little heavy I guess but the smooth ride more than makes up for that. I'm not sure what other Ti frames come in at to be honest? Seat clamp wise I went with the Burls Ti clamp, it weights about 31g so again a little heavy compared to some.
Yep, I think we're all on the same page who have tried both carbon and ti frames
