Show me your ti bikes
Moderators: maxim809, Moderator Team
Thanks! It's actually stiffer than I expected, due to the (almost) level top tube and tapered forks. It's plenty fast though, and also pretty light, the setup with 23mm Veloflexes is a smidge over 7kg with pedals.
@Marin that is a beauty. Are you using the same calipers on your road and cx setups? Mind going through your build choices?
@Marin, that is gorgeous. You must be using some long reach brake calipers to be able to accommodate both a road tire and a much bigger cross type tire?
Marin: it is not often that a modern bike looks that good with shallow rims. Job well done!
