My Colnago C60
Hi all,
Thought I'd share my Colnago C60 that I've had since Jan. 2015.
Frame & Fork: Colnago C60, 52s
Seatpost: AX Lightness Daedalus
Saddle: AX Lightess Leaf II
Crankset: Campy SR 2015 172.5
Chainrings: Campy SR 2015 52/36
Shifters & Cables: Campy SR 2015
Chain: KMC
Brakes: New EE Cycleworks brakes
Stem: 3T ARX LTD, 100mm
Handlebar: 3T Ergonova Team
Pedals: Look Blade 2, Ti, 16NM
Wheelset: Corima Viva MCC “S” with Vittoria Corsa Competition (25' at the front and 23' at the back)
Weighing in at 6.34 Kg with Garmin mount and one Arundel Mandible cage.
Chain: KMC
Looks like and sounds like it weighs the same as 75% of the rest of the bikes here. Is that a black cassette though?
Spring propel viewtopic.php?t=140915
Fall guru merus viewtopic.php?t=155877
Summer carver nonsense viewtopic.php?t=156795
It's a SRAM Red 11-28 Cassette.
Mine red 11-28 isn't black. I want a black cassette. Is it the lighting? How does it shift with SR? With di2 or indexed dura ace bar ends SRAM doesn't seem to shift as well as a matched cassette.
It only looks black as it has been used and the bike/drivetrain needs some cleaning.
Shifting is flawless with Campy SR. I also use those wheels/cassette on my Parlee Z1 fitted with DA9000 mechanical. No problem there either.
Interesting build....similar to mine. Expect mine to pop up in the "Introduce Yourself" catetory.
How are those wheels treating you?
THE PAST: 2005 C'dale R700, 2006 Spesh S-Works Tarmac Gerolsteiner, 2009 Pinarello Dogma FPX My Way, 2011 Time RXR VIP
THE PRESENT: 2016 Colnago C60 ST01, 2017 Wilier Cento 10 Ramato, Cinelli Gazetta
THE FUTURE:
THE FUTURE:
jimaizumi wrote:How are those wheels treating you?
I like them a lot; ~1,000g for the pair, extremely stiff, and very good braking in the dry. It gets trickier in the wet though, especially with the Corima cork pads.
Looks great, Nael!
How does the C60 compare to the Z1?
Hey buddy!!
Z1 is more compliant and geometry slightly less aggressive than the C60.
C60 descends with more confidence; it has more the character of a racing bike than the Parlee. I would take the latter for a relatively longer ride though.
- willowwonka
Very nice! Like the seat and seatpost combo, needs an AX stem to match!
I'm surprised it doesn't weigh less especially with the EE brakes.
- CANYON KATUSHA TEAM ULTIMATE SLX SUMMER RIG.
- CANNONDALE CAAD10 ANNODISED WINTER SLOG.
The frame is not the lightest on the market. 6.34 is almost as low as it gets for a C60.
Beautiful build. Corimas were a solid choice
