Specialized Edition Allez Sprint 2X
The first time I saw this bike online, i fell in love. After much effort searching for this unicorn (only 120 pcs worldwide), I finally managed to get it!
The bike is stock - only added pedals and bottle cage. The stem is ridiculously short (80mm). I need a 100/110mm stem to get the fit dialled in perfectly.
Weight? Didn't manage to get it weighed but will update once it get it done. I suspect about low 7kgs, partly because of the wheels.
If you want a full build list - see the link below:
https://www.specialized.com/us/en/bikes/road/specialized-edition-allez-sprint-x2/116152
How is the ride? It's stiff (as stiff as my CAAD10). It's not that responsive (hard to get up to speed - but then again, this is my main bike http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=130906&hilit=parlee+z5) but once at speed, it can hold speed well (it's due to the wheels more than the frame). I only did a 30km spin, so I will provide a more detailed update once I get my position dialled in and I ride it a bit more.
Finishing and paintwork is fantastic, the polished silver is amazing. The choice of components is top-notch. It's one of those bikes that you really don't see a need to swap out the stock parts.
I hope you like the bike as much as I do. More updates to come!
What makes this a limited edition?
Congrats! Sharp looking ride.
I'd love to hear more comparisons between this and the CAAD10. I've always felt the CAAD10 was unresponsive, and I was under the impression this frame was stiffer and snappier.
"Deserve's got nothing to do with it." William Munny
I just booked one of these at the weekend, didn't realize they are a limited run, supposed to arrive at the shop this coming weekend. Only thing I plan to change is to stick my Rotor 3D+ Inpower cranks on it.
Sent from my turnip using Tapatalk
@F45 - I am not too picky with saddles (Selle italia SLR on my parlee; fizik arione on my CAAD10) but I find the saddle comfy especially when you are in the drops because of the truncated nose portion (a bit like ISM saddles)
@IamnotWiggins - a limited paint scheme and higher spec components differentiate this bike from other Allez Sprints. Other than that, I believe the frame is identical to the standard Allez Sprint 2x frames. Call me a sucker, but the polished silver finish is a sight to behold and worth the extra $$$.
@boysa - I will post a more detailed report once I get more miles in and my fit dialed in. I think the wheelset is a bigger factor in a bike's responsiveness than the frame, especially accelerating from standstill. But yeah, all things equal, I would expect the allez to be somewhat snappier than a caad10. Maybe i should use the same wheelset for a fair test...
jonloh wrote:@IamnotWiggins - a limited paint scheme and higher spec components differentiate this bike from other Allez Sprints. Other than that, I believe the frame is identical to the standard Allez Sprint 2x frames. Call me a sucker, but the polished silver finish is a sight to behold and worth the extra $$$.
I won't call you a sucker as it's a lovely looking bike! My Allez e5 winter bike is the polished version and I know what you mean about the finish. And hey, who doesn't love something that's a limited edition.
@Zak - i believe the bar tap was wrapped starting from the top of the bars, moving towards the bar-ends so that the finishing tape would not be needed. Essentially the opposite direction from the traditional way of starting from the bar-ends.
@IamnotWiggins - is there a particular way to keep the polished silver finish in good condition? any special cleaning techniques?
@emcardle - yup, it's a 49 with a ridiculously short 80mm stem that comes with the bike.
@Fixie82 - no special cable routing. The bike shop just used the shortest housing possible as you can see below.
@jonloh - I tend to use furniture polish to bring out the shine. Just wash it as normal using whatever you normally use then buff it up.
