Imaqueen, go away...
Updated kit with the Boras rolling on the fatties (27mm Vlaanderen):
Weight increased a bit as the SRM was +100g over the SRAM Red setup and I went to SR Dual Pivot Rear (+25g) to get the necessary clearance for Vlaanderens. I did drop about 40g on bottle cages. Currently hovering around 14lbs or 6.3-6.4kg. With the CCU and KCNC skewers it's 6.2kg. Schmolke is doing a buy two TLO and get 20% off and I'm really trying to resist that. Right now everything is dialed in and perfect anyway, so I'm not sure if I want to mess with new bars, a new shape and possibly needing a new stem.
I bought another CK PF30 bottom bracket that's sitting on my desk. I'll put that in this weekend since the SRM is barely clearing the SRAM PF30 delrin cups. I'll be going the loctite route this time with the CK BB though, since last time it was making noise with copper paste after several thousand miles. I also have an Ag2r blue SRM PC8 coming, which should be a perfect match for this bike.
Also, first ride today with the MKV rings and they shifted flawlessly. Pickup was very quick and transition from big to little and back was lightning quick. Definitely hoarding some more of these.
