nbon wrote:just wondering about the bb: Bottom Bracket: Wheels Manufacturing PF30 Threaded - 104g
Does it work with the BB30a frame out of the box? Or is there any additional work needed to install a PF30 in a BB30a frame? Did you make any change to the original SISL2 crankset to make it work with the PF30 bb (maybe spindle length)? What is the exact name of the bb you ordered?
Thx!
The 2016 HiMod is not BB30a. Cannondale confuses things with their terminology. On the website currently they call it Pressfit BB30a. The plastic cups are simply pressed into the frame and there aren't any "clips" like BB30, so PF30 works just fine.
The Wheels Manufacturing PF30 Threaded BB installed just fine straight out of the box. You will also need the 48.5mm wrenches listed under "required tools" to thread it together (and an extractor if you need to get your old cups out).
Here's a link to the exact BB I installed in my 2016 HiMod
PF30 THREADED ZERØ CERAMIC BB (BLACK) Any of the bearing options would work though.
As for installation of the crank, I didn't make any changes when I originally installed my crank (had Dura Ace mechanical at the time), but with Red eTap I added a thin spacer shim to add clearance to the eTap front derailleur. Otherwise, no hardware changes, stock spindle worked just fine.
