cooper
by cooper on Sun Jan 01, 2017 9:59 pm
nonamed wrote:You trimmed the Save seatpost by 50mm ?? Your was 350mm length before cutting with Di2 insert?
I have had 2 SAVE carbon posts. Both times they were 300mm long (original length). If you cut off 50mm you'll be cutting at the end of the aluminum insert. The 50mm of carbon and aluminum Di2 insert is roughy 35-40 grams.
ryanw
- in the industry
by ryanw on Sun Jan 08, 2017 7:20 pm
I'd like to see the 60mm Conti Lite tubes on the scales. I've had over 10 of these and the lightest I've had was 73g, normally 75-77g.
Your stats claim yours are 66g each...
PS: Go with the Supersonics and save another 50g for £18!
Durisic
cooper
by cooper on Fri Feb 24, 2017 2:30 am
mcgheew wrote:did you have any setup issues with the rear eebrake? I found I had to use nokon cables on my 50cm evo frame (outgoing model)
My rear eebrake was a little mushy with standard housing. I switched to jagwire elite housing just for the short section from the frame exit to the rear brake. That improved the brake feel considerably and it feels totally balanced and normal now with the front.
mcgheew
by mcgheew on Fri Feb 24, 2017 4:15 am
cooper wrote:mcgheew wrote:did you have any setup issues with the rear eebrake? I found I had to use nokon cables on my 50cm evo frame (outgoing model)
ah yep I see in the later photos. cool, will try out jagwire next time for a change
Jepas
jlu
by jlu on Fri Sep 29, 2017 10:33 am
beautifull bike! do you think size 52 will also fit me? Im 170cm with 81cm inseam. center bb to saddle 700mm. what is your size and inseam? thanks
cooper
by cooper on Fri Sep 29, 2017 8:32 pm
jlu wrote:beautifull bike! do you think size 52 will also fit me? Im 170cm with 81cm inseam. center bb to saddle 700mm. what is your size and inseam? thanks
FWIW, I'm 170 cm with 76 cm inseam. Center BB to Saddle on my bike is 71 cm. The bike currently has a 100mm stem on it.
cooper
by cooper on Tue Nov 14, 2017 4:28 am
I didn't save 87 grams with the spindle. I didn't even change the spindle. That is the stock spindle (as far as I know there is only one 109mm spindle). It's just a dash "-".
That said, I did save a fair amount of weight going from the 8 arm 52/36 Si spidering to the 10 arm 50/34 SiSl2 (as I recall on the order of ~50 grams)
Aya
by Aya on Sat Jan 27, 2018 10:46 pm
Hi, Could you let me know the name of the top cap? I am looking for a really thin top cap, and that cap in your image looks quite thin!!!
cooper
by cooper on Sat Jan 27, 2018 11:26 pm
Aya wrote: ↑Sat Jan 27, 2018 10:46 pm
It isn't a standard top cap.
Cannondale has a top cap and expansion plug that were designed to work together. They were standard Cannondale parts on my HiMod.
You can see the parts
here (along with a lot of other headset parts you probably don't need)
