Godzuki26 Wife's Cannondale Evo HiMod 48cm build [3.96 kg] or [8.73 lbs]
Put some normal genuine hoods on shifters .
godzuki26 wrote:She is not allowed to run spacers under the stem. It must look good. It must be slammed. She does Yoga and Crossfit so she is getting into a pro position whether she likes it or not. Lol. She thinks cycling is easy. She needs to be schooled.
"She needs to be schooled"... hilarious:-)
TA
tadrums wrote:godzuki26 wrote:She is not allowed to run spacers under the stem. It must look good. It must be slammed. She does Yoga and Crossfit so she is getting into a pro position whether she likes it or not. Lol. She thinks cycling is easy. She needs to be schooled.
Actually, if you get on her bad side, she'll intentionally puncture and make you change her tires... Karma works both ways, you know
THE PAST: 2005 C'dale R700, 2006 Spesh S-Works Tarmac Gerolsteiner, 2009 Pinarello Dogma FPX My Way, 2011 Time RXR VIP
THE PRESENT: 2016 Colnago C60 ST01, 2017 Wilier Cento 10 Ramato, Cinelli Gazetta
THE FUTURE:
THE FUTURE:
Here is the genuine BTP tuned Campagnolo front derailleur. It has holes drilled in the main body, material shaved off on the main body & inner cage bolts shortened down, and carbon pins in place of steel pins. I was planning to throw on a titanium spring to save more weight but decided not to. The carbon pins are glued in and it will be difficult to remove them without breaking them.
BH Ultralight
Litespeed Ghisallo
Scott Addict Singlespeed
Felt AR FRD
Litespeed Ghisallo
Felt AR FRD
If the front derailleur looks shaved up, the rear needs to also. It's the ugly derailleur contest. I shaved aluminum off the rear derailleur when I was planning not to. I went from 146 grams to 123 grams to 114 grams. I do not know how to get to 100 grams or less. I have seen people do it but I don't know if I can remove more without feeling uncomfortable about durability. Right now I still need to make the barrel adjuster bolt shorter. Does anyone have any more suggestions on what else I can do?
BH Ultralight
Litespeed Ghisallo
Felt AR FRD
Litespeed Ghisallo
Felt AR FRD
Throw those jockey wheels away. Pure trash. They turn to shit after 20 miles.
dudemanppl wrote:I have to warn you, those pulleys are absolutely complete shit. Take them off, you'll thank me later.
I have those jockey wheels on my Ghisallo.....and you warned me of the same thing.....but I haven't ridden the Ghisallo yet. Lol
BH Ultralight
Litespeed Ghisallo
Felt AR FRD
Litespeed Ghisallo
Felt AR FRD
Since everyone hates the BTP hoods, I thought I try and see how much weight can be saved by hole punching standard SRAM hoods. 27 grams for the BTP hoods. Can I get close? At 39 grams the answer is NO.
BH Ultralight
Litespeed Ghisallo
Felt AR FRD
Litespeed Ghisallo
Felt AR FRD
Cool I need to do this to mine. Tedious or easy?
I was ridden with same jockey wheels about 750km , and then they was totally broken.
Can heatshrink be used instead of hoods? I think it demands some sort of soft material on the top, maybe an inch (wide) of the puntured hood or a strip of bartape for weightweeningin' and then heatshrink on top of it...then patience with a stanley knife
