Godzuki26 Wife's Cannondale Evo HiMod 48cm build [3.96 kg] or [8.73 lbs]
I shipped my bike off 4 days ago for clear coat as mentioned earlier. Before sending it, I made mock logos. Of course they will be black logos with transparent background. Also, I am putting my wife's name on the top tube and it will be under the clear coat. With her name now on the frame, she must be committed to the bike or I can't resell it. Will she like the WWII Kamikaze flag next to her name??? Probably not, but I think it will look groovy in black on black So, there will be a total of 3 decals on the bike. I decided to leave the head tube blank.
BH Ultralight
Litespeed Ghisallo
Scott Addict Singlespeed
Felt AR FRD
Litespeed Ghisallo
Felt AR FRD
I got some items from Starbike for the wife's bike. I saved some weight here. Check it out.
15 grams for the Cannondale 30.8 seatclamp Oh hell no. That is way too heavy! Plus it is red.
Replaced it with the Tune Würger Skyline 2.0 Seat Clamp. The carbon bands are UD to match the frame
BH Ultralight
Litespeed Ghisallo
Felt AR FRD
Litespeed Ghisallo
Felt AR FRD
The Cannondale System Integration topcap and expander was not that bad at 16 grams. But, weight can still be saved.
First start with the Extralite Ultrastar 3
Then get a carbon topcap. For this I got the Tune but will be sanding the logo off.
Then throw a nylon M6 countersuck screw on the 2 units and I cut the weight in almost half.
BH Ultralight
Litespeed Ghisallo
Felt AR FRD
Litespeed Ghisallo
Felt AR FRD
I have been using the Tune Skyline Time Trial skewers on all my bikes. My wife and I need to match, so she gets the same thing. Plus, when we ride together, I will always have the skewer tool. You can't beat 17 grams.......Unless I trim the ends:)
BH Ultralight
Litespeed Ghisallo
Felt AR FRD
Litespeed Ghisallo
Felt AR FRD
I like the Tune Edelzwicker lockring. I use 2 others on my bikes and they are 3 grams. This one came in a little heavier.
BH Ultralight
Litespeed Ghisallo
Felt AR FRD
Litespeed Ghisallo
Felt AR FRD
And finally, the 80mm MCFK stem.
Take the ugly ass stickers off and I save 1 gram
BH Ultralight
Litespeed Ghisallo
Felt AR FRD
Litespeed Ghisallo
Felt AR FRD
So with the 164 gram 36cm S-Works handlebar, the combo weighs 243 grams. I wonder how much weight I can save if this is turned into a barstem combo removing the aluminum faceplate and bolts? If this stem is the right length, I will consider it.
Since the frame will be in a matt finish, I will need to refinish the stem. I do not know why MCFK charges an extra 50 euros for the matt version. I would rather pay less and do it myself. The Ax Lightness Orion brakes are also gloss and I will be refinishing them too. Is sanding with 1500 grit the best way to do it? Or is there an easier way? Thanks.
BH Ultralight
Litespeed Ghisallo
Felt AR FRD
Litespeed Ghisallo
Felt AR FRD
Ha! The relative price of the kitchen remodel just went WAY up! But you're gonna love it.
I should go look in the kitchen forums to be sure
BH Ultralight
Litespeed Ghisallo
Felt AR FRD
Litespeed Ghisallo
Felt AR FRD
Ha! Her username is "NoLimitSally". She talks about you all the time. You WILL learn to cook.
I took some 1500 grit sand paper and wet sanded to get some of the gloss shine off. It is kind of hard to see in the photographs, but I decided to post it anyways so I can reference this later on when I want to try this again. So here it is.
With the gloss.
After wet sanding with 1500 grit.
A comparison on the Ax Lightness calipers. The left is still gloss, the right after the wet sanding.
With the gloss.
BH Ultralight
Litespeed Ghisallo
Felt AR FRD
Litespeed Ghisallo
Felt AR FRD
Lookin good! You could hit it with some 2000 grit wet if you still see some scratches.
@Kevosinn - I do see scratches. Heading to PepBoys now to get some 2000 grit. Thanks
BH Ultralight
Litespeed Ghisallo
Felt AR FRD
Litespeed Ghisallo
Felt AR FRD
Just get the highest they have. Might have even 2500. Work your way up the grits and keep dunking the paper in water to keep it clean.
