Finished my Caad12
Hapsmo911
by Hapsmo911
Still need to weigh it. Just finished tonight. Need to make some adjustments and then cut the steer tube. Enve stem, and post, Etap, SiSl cranks, ProVibe rounds, and red brakes. Campy wheels will suffice until the Enves show.
ChiZ01
by ChiZ01
the long and low caad geometry doesn't seems to fit you, hence the short stem and spacer tower
Hapsmo911
by Hapsmo911
ChiZ01 wrote:the long and low caad geometry doesn't seems to fit you, hence the short stem and spacer tower
The stem is 100mm. I havent made any adjustments. I snapped this pic after I put the last part on.
vejnemojnen
by vejnemojnen
please, also keep in mind, that he does not uses short reach compact bars, rather, a longer round one (which also adds to the reach..) and there seems to be a hwege saddle-bar drop.
this frame fits him just fine, i guess.
martinko
by martinko
Don't mind the troll, he even missed the campag wheels mixed with a sram groupset. 1cm of spacers on top of the conical one looks ok to me.
LeeCH
by LeeCH
How much does it weigh? I think it is lighter than other same group bikes much.
