Kayrehn
by Kayrehn on Fri Aug 12, 2016 12:22 am
dudemanppl wrote:Are you gonna run your Osymetrics clocked like that? I think that defeats the purpose...
Nope, that's just arranged for the sake of the picture, it's not bolted on. Eventually round rings will be coming anyway and it'll go back to the Madone.
Kayrehn
by Kayrehn on Fri Aug 12, 2016 2:38 am
dudemanppl wrote:Ah I see. Whered you get the tennis tape? That's crazy light!
It's really common in racket game equipment shops around here. These are usually used for tennis rackets and I don't usually use them for badminton rackets (I play the latter not the former). They have a very tacky feel, excellent grip and dog hair sticks very well to it [emoji16]
For the purpose of a weight weenie build it's awesome.
kkibbler
by kkibbler on Fri Aug 12, 2016 1:40 pm
Saw this bike at the LBS. Looked good.
#noweightspoilers
Any particular reason why you didn't opt to build it up yourself? You had all the parts and it should have been quite straightforward, and it doesn't get much easier than eTap to install. Just curious.
Kayrehn
by Kayrehn on Fri Aug 12, 2016 4:22 pm
kkibbler wrote:Saw this bike at the LBS. Looked good. [emoji106] #noweightspoilers
A fellow SGer! I never have the aptitude for stuff like this - inevitably something would crop up and I'll have to haul the bike to the shop sheepishly to explain my failed DIY effort. Don't have quite a bit of tools also.
Bike just done up, but more to come. Just got this, for example.
KCookie
by KCookie on Fri Aug 12, 2016 10:29 pm
Hey mate, looking forward to the final build. I'm the same as you the only time I tried working on my bike I made it worse and ended up down the LBS looking like an idiot.
Those Fibre Lytes didn't take long to be delivered.
What do you think final weight will be. ?
xena
- Banned
Kayrehn
by Kayrehn on Sat Aug 13, 2016 7:57 am
KCookie wrote:Hey mate, looking forward to the final build. I'm the same as you the only time I tried working on my bike I made it worse and ended up down the LBS looking like an idiot.
Haha looks like it's easier to just get the professionals do the job for us. I have a feeling it'll be 5.1kg in the end, and it'll be hard to make it go lower after all the intended parts go up.
I can't use powercordz too unless I get a solution for the brake clamp bolts, so steel cables will weigh a bit more though the housing can still be used. After bike fit is done that'll go up and cutting down the steerer will save a bit more.
KCookie
by KCookie on Sat Aug 13, 2016 8:46 am
Kayrehn wrote:KCookie wrote:Hey mate, looking forward to the final build. I'm the same as you the only time I tried working on my bike I made it worse and ended up down the LBS looking like an idiot.
Yeah I went for Jagwire in the end for that particular reason. 5.1kg is an awesome weight, so close to being in the 4s though. Ive bought Veloflex Carbons which will bring the weight down by 38g and still waiting on Xpresso 15s to be in stock which will save another 20g, still no where near your 5.1kg but will get me under 5.5kg.
Kayrehn
by Kayrehn on Wed Aug 24, 2016 12:50 am
Unfortunately it'll be a month before I get the whole thing up unfortunately - bike fitter says he'll help with ordering the Berk combo but he haven't replied me for a week. We'll have to see how fast Berk gets the combo done too. (Hey Berk, if you get an order from Timothy, that's for me! [emoji1])
Bikefit done and 130mm stem recommended instead, so got myself a Kalloy stem with some ti bolts. The weight is unbeatable for a stem of that length (without going the ax lightness way). Hope the graphics go off easily without fuss.
Anyway, I managed to hunt down a pair of brake cable clasps which will allow me to tie up the powercordz cable onto it, so that's something to look forward to.
anlimdy22
by anlimdy22 on Thu Sep 08, 2016 6:08 am
Kayrehn wrote:Some goodies finally arrived!
Haerocarbon bars 40cm o-to-o. A little disappointed the ovalised top isn't as wide like the Ergonovas, or so I remembered, but it'll feel better than round to me still.
120mm, -12 degrees
Carbonice parts, nice stuff. Not sure how to tell the difference between the top and bottom wheel though...
I bought carbonice Eva 2.0 for my Fuji SL 1.1 but can't tighten the seatpost. How about your case?
anlimdy22 on Thu Sep 08, 2016 7:08 am, edited 1 time in total.
gangbyeon
by gangbyeon on Thu Sep 08, 2016 6:59 am
It is really a combination of expectation.
Etap was satisfactory to the weight and performance.
I look forward to be completed.
___________________________
Canyon Ultimate cf slx 9.0 swiss - 5.6kg
