It is currently Tue Aug 22, 2017 12:21 pm
Post new topic  Reply to topic  [ 111 posts ]  Go to page 1 2 3 4 58 Next
 Post subject: Kayrehn Fuji SL 1.1 <5kg
PostPosted: Tue Jul 05, 2016 1:34 pm
Goal - Sub 5kg, under 7.5k usd (which works out to 10k in my local currency)
Was a choice between this and the Ax lightness vial but even the R version of the latter cannot go close to my current Madone H1 geometry, and with the silly low price of the Fuji SL the choice is clear.
Things aren't off to a promising start though
That weight is for a size 54 without bottle cage screws, seat collar, headset and the cable guide piece with straws for shift cables. Was hoping to get under 750g and now I'm almost 20g off in my calculations.
(Update)
Final Build list with weights
Components Item Weight
Frame Fuji SL 1.1 769
Fork (uncut) Fuji SL 1.1 280
Stem Kalloy 130mm 108
Stem bolts Black titanium bolts 11
Bars Haerocarbon RR145 SL 40cm 158
Shifters Sram Etap 265
Rear D Sram Etap Wifli(No pulleys) 219
Front D Sram Etap 135
Batteries Sram Etap 49
Brakes EE brakes 174
Brake shoes Corima Cork 8
Wheels Extralite Cybermax 32 898
Cassette Sram XG 1190 (11-26t) 158
Tires Vittoria G+ Corsa Speed 23mm 410
Valve extender FFWD 20mm 5
Cranks Sram Etap BB30 365
Chain Rings Fiberlyte 52-36 85
Chainring bolts Fouriers 13
Pedals Look Keo Blade 2 Ti 192
Bottle Cage Chinese unbranded 17
Seatpost/Saddle Berk Combo 166
Bottom Bracket F1 ceramic PF30 83
Chain KMC X11 SL DLC 218
Seat Collar Carbonice Eva 2.0 6
Headset FSA 47
Brake cable Powercordz 7
Steerer plug Schmolke ahead plug 6
Bar end plugs Deda (Drilled out) 2
Derailleur pulley Carbonice Hanni und Nanni 8
Skewers J&L Ebay lock skewers 28
Bar tape Supacaz 34
Tubular glue Mastik 1 20
Garmin Mount Raceware (510 version) 11
Cadence sensor Garmin 10
Bottle cage bolts Ebay alloy 4
Etap blips Skunkworks 3
Rubber tape Ebay china stuff 4
Stuff I didn't weigh accurately - Cut fork, small bits of sugru to cover port holes, protective tape at BB area
Total rideable weight with pedals - 4.96kg
Trek Mad-one 7 Series team colours http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=115500&start=15
Fuji SL 1.1 http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=140134&hilit=Fuji
PostPosted: Tue Jul 05, 2016 3:59 pm
I'm really looking forward to this! Subscribed.
PostPosted: Tue Jul 05, 2016 4:23 pm
Subscribed. Though 10k can't exactly be classified as budget leh
Sent from my SM-G920I using Tapatalk
My Tarmac SL3 http://weightweenies.starbike.com/forum/viewtopic.php?t=136991
PostPosted: Tue Jul 05, 2016 5:04 pm
It is a budget ww build if I can't throw on a THM crank
Other parts of the frame...
An integrated chain catcher, light enough for me to keep it.
Headset is pretty light too, not sure if I can get it lighter even with Extralite headset so it's staying.
This is definitely going out...
This solid piece goes onto the bottom to replace the cable guide if you're using Di2 - will it be ok to leave it out since I'm using a PF30 BB shell?
PostPosted: Tue Jul 05, 2016 10:47 pm
Uh, why Di2?
I thought this was a weightweenie+low budget build.
Screams SRAM RED 22
PostPosted: Tue Jul 05, 2016 11:40 pm
Online
+ 1000 :lol:
Louis :)
PostPosted: Wed Jul 06, 2016 12:20 am
I have a Fuji Transonic and the included headset weighs 132g. Are the headset you have made a aluminum? How can there be such a big difference in weight between headsets? I wish to know if I could upgrade to the lighter one. Do you mind posting the headset measurements for me (i.e. ID and OD)? Btw my fork doesn't use a bearing crown. I don't know if the SL is the same way. Thanks.
PostPosted: Wed Jul 06, 2016 2:56 am
Subscribed also. Thinking of starting on a similar project but unsure whether to use the Fuji or an Argon 18 Gallium Pro, similar weights & $'s. If this comes in under the 5kg target and on budget I'll pumped for you :)
Ahhh, coffee & carbon
PostPosted: Wed Jul 06, 2016 3:04 am
3% off expected weight surely isn't the end of the world? Do rate Fiji's though, this one should be good.
And I can't wait to share my budget Lamborghini build. $10k 'budgetweenie' :lol:
http://www.nicksquillari.com.au
The Gram
The Men of Steel
PostPosted: Wed Jul 06, 2016 6:33 am
Running a tight ship trying to get the weight within limit. One issue is that almost all the parts have been ordered so to be thrown off by 20g can be difficult. Wouldn't be the end of the world (or build) if it goes over 5kg but the fun is in the challenge.
Anyway, 10k is in my currency; 7.5k usd is tight if you wanna get top end stuff.
Ill try to measure the bearing cup OD. Extralite Ultratop and Ultrabottom were options I considered if they were heavy. Madcow also gave the suggestion of KCNC ones.
PostPosted: Wed Jul 06, 2016 7:26 am
My friend build up his Izalco Max to 5.39kg and it only cost 2700 USD... I hope it doesnt take 5000 dollars to lose 390 grams.
PostPosted: Wed Jul 06, 2016 11:14 am
dudemanppl: I think it is a bit unfair to compare it with the Izalco Max your friend built, since from what I see by googling an Izalco Max frame costs already about 3000Eur new + Red would be about 1400Eur extra. I assume your friend bought a used frame and has a big spare parts bin?
PostPosted: Wed Jul 06, 2016 5:19 pm
Nope, that is the complete purchased price. Nothing from the parts bin.
PostPosted: Wed Jul 06, 2016 5:21 pm
OK, but I guess then it must be many used parts. My point is that 5000 dollars is not the price of losing 390gr, but of losing 390gr and having new instead of used parts. Anyways, not important :D looking forward on how this turns out.
PostPosted: Wed Jul 06, 2016 5:59 pm
This contributes to the weight and cost of the project, but it is also the motivation to start the build.
There are no new unread posts for this topic. Fuji SST 1.0 Aero set up
jchehan
Mon Feb 27, 2017 9:49 pm
Allen254 View the latest post
There are no new unread posts for this topic. Allen254 Fuji
Allen254
Wed Jan 11, 2017 10:00 pm
reedplayer View the latest post
There are no new unread posts for this topic. 2018 Fuji SL
Roni1
Tue Aug 01, 2017 4:58 pm
Hamfist View the latest post
There are no new unread posts for this topic. 2018 FUJI SL 1.1 54cm
Drpoomanchu
Fri Aug 11, 2017 3:58 pm
Drpoomanchu View the latest post
There are no new unread posts for this topic. Experimenting with bike sizing: Fuji SST 1.3
istigatrice
Wed Jun 14, 2017 12:58 pm
jbaillie View the latest post
Users browsing this forum: CrankAddictsRich, LouisN, shamrock134 and 13 guests
