Lightweight Urgestalt. UPDATE, new parts 30.9.2017
- Location: Global Citizen but mostly in Australia and Asia
Nice! Obie Schwarz! You really splashed it all out on this rebuild!
AUOC1OC6
AX Lightness Vial Evo D http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138599
Corima Puma
Giant MCR 2 (retired)
Trek Y Glide Deluxe MTB
Corima Puma
The chainrings are now on correctly, but the shifting is terrible, just a quick spin up and down the street and the chain doesn't seem to want to go up on to the big ring, just rattles around for quite a while then painfully engages. Not to happy atm.
Any ideas what could be wrong, thought it would be quite smooth with DI2. As THM suggests stick with Praxis, maybe I should have listened but the Fibre Lytes look awesome. !!!
Cheers
Cheers
- maverick_1
@KCookie,
Are the lift pins correctly positioned?
If they are, IMHO minor adjustment on the FD should do the trick.
Bring it over to your LBS to have it adjusted, I wouldn't risk damaging the carbon rings on the Fibre Lytes unless you're confident enough with fine tuning the Di2 FD (Campy guy here unfortunately)
Nice bike btw..
Cheers
Nice bike btw..
Cheers
Hi Maverick_1
Yes the pins are correct now, wouldn't have a clue about adjusting the FD, getting quite fed up going back and forth the the LBS as it's close to an Hour each way.
Cheers, yes I love the bike, just want to be able the ride it.
You need a new bikeshop. That's unacceptable they built a bike for you and didn't check shifting.
This video should be pretty straight forward, may be a good start into wrenching yourself:
https://www.youtube.com/watch?v=PU2kQp9IeBc
- maverick_1
+1 on a new bikeshop..
Hopefully this is not the same shop that took almost a year to replace your frameset.
Cheers
Cheers
RyanH wrote:You need a new bikeshop. That's unacceptable they built a bike for you and didn't check shifting.
The video did make it look easy. I gave it a go and completely mucked it up, the FD now rubs on the chainring. Thats why i dont work on bikes, im useless.
Will try a different shop.
Sent from my SM-G925I using Tapatalk
That looks very nice .
If you want to get a similar natural logo look on your downtube [ stealthy]
Just use some decals on your nude carbon frame press them down hard , remove them after a few hours and you will have the exact same effect. It really works.
xena wrote:That looks very nice .
Cheers Xena, yeah it's a shame the logos in white, would deff look better in black. !!!
I think they may have skipped an important step when adjusting the upper and lower limit screws. For the upper, put the chain in the big ring and smallest rear cog and adjust the limit screw so there's about 1mm of clearance on the outside of the cage and the chain. For the lower, put the chain on the little ring and biggest cog and adjust the limit screw so that the inside of the cage has about 1mm of clearance. That should resolve your rubbing issue. If not, let us know where it's rubbing and maybe a pic and we can maybe help further.
Sent from my SM-G930V using Tapatalk
Great Bike !!!
This is one of nicest bikes on WW forum.
Only small visual flaw are those red pedals. Other than that, it is perfect.
My Wilier Zero7: http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=116053
And Ridley X-Fire Disc http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=124026&p=1056055#p1056055
