Ryan's Aero Acceptance: Scott Foil Team 2016
Strava
Frameset weight seems to be close to claimed. This is a 52 with the SRAM GXP BB92 Bottom bracket Installed and derailleur hangers @ 1065g:
Seatpost, uncut @ 192g:
I'm going to need to source a lighter bolt, holy smokes is that a heavy clamp bolt:
I'll post more later.
Strava
Thats a 52? I thought it was a 56 from the head tube length!
RyanH wrote:Hi, my name is Ryan...and I have a problem:
Looks like you found a solution, keep it up
BMC TMR01 --> viewtopic.php?f=10&t=131523&hilit=tmr01
Colnago Master X Light --> viewtopic.php?f=10&t=140479
@dudemanppl
It's a little deceptive since the HT starts above the lowest part of the DT and is lower than the TT. It's 13cm HT for a stack of 52.6mm, which is about the same as the Fuji Altamira in S/M.
Strava
A few more parts for tonight, then I'll get into the proprietary parts that will make this a challenge to stay in the 13lbs range.
The fork is respectable, and should be under 300 when I lop off a couple more cm (hopefully). Crown race is molded carbon. Scott Foil Team Fork @ 311g (a little already cut off):
Syncros Headset @ 63g
Good ol' SRAM Red GXP Quarq in 53/39 @ 760g:
That'll be an easy place to drop 50g by replacing the rings.
Should I sand these again? Doesn't save much weight but keeps the visual flare to a minimum. From my Litespeed:
Strava
Woah, light fork! I noticed you kept the steel chainring bolts on the Litespeed, why tho? Easy like 10g right there. And yeah the stack numbers are about right, thats weird.
Nope, SRAM Red ships with alloy chainring bolts that are about 10g for the set.
Strava
- Juanmoretime
- Administrator
Ryan, this one interests me more than your Cervelo. When I was time trailing I was on a Scott Plasma 2 and loved that bike. At the weights so far a sub 13 lb bike is very doable.
RESIDENT GRUMPY OLD MAN.
This is going to be great. Still riding the Ostentatious Cervelo for now?
I'm in the process of selling off the Uber parts on the Cervelo so it's semi out of commission until I get some replacement parts. I have another etap upgrade kit coming soon so in the mean time I'll harvest that too off the Cervelo.
Getting this under 6kg will be hard. I'll post some more scale shots later today which will show why. An order from Toronto cycles will definitely be necessary.
Sent from my SM-G930V using Tapatalk
Strava
This is gonna be rad!
Okay, so to continue on with the small parts. For those of you that overlook the small parts, this is where you can get killed weight-wise. I'll definitely need some input on tuning these.
Stock cage bolts, will be replaced with alloy bolts 17g --> 2.8g:
Seatpost internal binder @ 20g (bolt seems to be alloy and is drilled and internally threaded, not going to be able to do much with that):
The item on the right is the cover for the seatpost binder and the one on the left is the BB hole cover:
Headset cover and spacers, don't need all of these @ 37g:
Only need 17g worth:
The biggest offender, the fork expander @ 47g with top cap. Since the fork is 1.25, I need something that can expand up to at least 27mm, most are rated at 25mm:
Top cap and bolt by itself, will dig out Extralite bolt:
Cable stops made of alloy @ 8g:
Huge expander
Want this instead:
So, that's about 100g of additional "stuff"
Huge expander
Want this instead:
Strava
- Similar Topics
- Replies
- Views
- Last post
2016 Scott foil Crank Based Power meter Options
by BayAreaCycling » Tue Jun 27, 2017 12:40 am » in Road - 13 Replies
- 1605 Views
Last post by hannawald
Tue Mar 27, 2018 11:55 am
- 13 Replies
- 3669 Views
Last post by TonyM
Fri Oct 06, 2017 7:44 pm
- 6 Replies
- 648 Views
Last post by kelih
Fri Jun 23, 2017 3:11 pm
- 28 Replies
- 4491 Views
Last post by TurboKoo
Sun Dec 03, 2017 7:41 pm
FS: frameset Scott Foil 20, SOLD
by rainerhq » Thu Jan 18, 2018 5:21 pm » in For sale - Pictures are mandatory 22-3-13 - 0 Replies
- 227 Views
Last post by rainerhq
