Damon Rinard's 2016 Cannondale CAAD8 105
Maybe a wide Berk saddle? I think they're 150mm.
- in the industry
Thanks.
I like that Berk is making a wider saddle!
I'm putting this in my $/g spreadsheet.
Damon Rinard
Engineering Manager, Road Bikes
Cycling Sports Group, Cannondale
Ex-Kestrel, ex-Velomax, ex-Trek, ex-Cervelo
Yeah weird how he only makes 132 and 150 though considering Specialized defaults to 143.
- in the industry
The handlebar tape goes on.
Got a great deal ($0) on some Cannondale Synapse handlebar tape.
80 grams before, 26 grams left over, so should be about 54 grams installed.
From searching on here, I understand this is a pretty typical weight for "cork" handlebar tape.
This is somewhat in line with my old listings: http://sheldonbrown.com/rinard/weights.htm#tape
In this list, you can see here Cinelli cork was around 38-40 grams; it gets close to the Synapse tape, at 54 grams, if you include their rubber groove inserts. The heavier tapes, 66 grams and up, are padded vinyl, not cork.
The Cannondale Synapse tape, in additon to the "cork," has a layer of gel, so that may explain why it's on the heavy side. The stretch is great, makes it super easy to wrap. Also, the taper is right - it goes on smooth, not lumpy. I rode it today and the grip is good too.
Speaking of grip, Andreas Klier taught me about the right tape (and the wrong tape!) for Paris-Roubaix. In the 2009 race, Cervelo TestTeam used the standard team issue tape, I think "Cork" from Silva, and it was pretty normal cork tape for those days.
The riders requested the usual tricks: double wrapped, double only on the tops, etc., but on top, normal cork tape.
The next year, in 2010, several riders got severe blisters on the recon rides during the days leading up to P-R. Andreas figured out what had changed, and why it had such a different effect that year: the tape. Gloves were the same materials, no difference there. But the surface of the tape was sueded, or brushed, a kind of extra-grip surface. Sounds perfect for P-R, no? So perfect, Specialized called their version Roubaix tape.
Just searched google, and it easily found this 2008 article that mentions the Specialized Roubaix tape and shows a picture of it on Tom Boonen's handlebar (along with a ton of padding).
https://roadcyclinguk.com/gear/tom-boon ... A6mw6gA.97
Well, the pictures don't show up in the article for me, but google has it:
This sueded or brushed extra grip surface was what gave the riders trouble in 2010: As everyone knows, the cobbles made the bike move. Andreas put it this way: With normal tape, the movement happens between the tape and glove, but with grippy "Roubaix" tape, it happens between the glove and hand.
So for most roads, a brushed tape is good. But for cobbles, don't go for too much grip!
Cheers,
Damon
Code: Select all
MAKE MODEL MASS, g COMMENTS
3TTT Ergo groove covers 4.9 pair
electrical tape instead 6.17 about 5 feet
Tioga Hybrid 18 from 42cm bars w/1" cut from each side
Sampson Fat Wrap 22 from 43cm bars
Tioga Hybrid 23 cotton with synthetic bumps
Benotto thin 29 from 42cm bars w/1" cut from each side
CatEye Benotto style 31 uncut
Benotto thin 33 from 42cm bars
Benotto thin 36 uncut
Cinelli cork 38 from 38cm bars
cork ribbon 40 from 40cm bars
cloth 46 uncut, w/spools
Cinelli cork 53.57 as installed, w/o paper backing, w/plugs, elect. tape, rubber groove inserts
Bike Ribbon 66 uncut
Pelten bike ribbon 66 uncut
Schwinn Paramount 84 like Bike Ribbon, but from Taiwan
Cheers,
Damon
Damon Rinard
Damon - am loving this thread, same as everyone else it seems, and like you my sit bones are quite wide for a male. Earlier this year I had them measured for the first time after a position change was causing havoc down there. Turns out I need a super wide saddle and am currently rocking 168 Specialized Power saddles. I also have a Selle San Marco Regale Carbon FX (super long name) that is 155 wide and that has excellent comfort for me. I've used this on a 12+ hour ride and it was still ok at the end of that. It's quite light and comes in a design similar to the Cannondale saddle above. Definitely worth checking out.
- in the industry
glepore wrote:Make sure you get the light supersix expander from the corporate parts bin.
No doubt. That fork expander has been lightened to within an inch of its life. Chris Dodman did a ton of FEA to remove as much material as possible to save weight, while still retaining excellent support for the steerer wall. Chris is the genius behind the SiSL2 cranks, SpideRing, and other weight weenie Cannondale parts.
But for now my CAAD8's stock fork, the Cannondale Ultra, has an aluminum steerer and a normal star nut.
Anyone know what one of those weighs? I'm guessing maybe 10 grams?
Damon Rinard
- in the industry
@Fixie82: Thanks, those are some interesting saddles to consider. I'll add them to my $/g spreadsheet.
Damon Rinard
- in the industry
First ride yesterday.
7.900 kg as pictured, including Powertap hub:
Rides great!
- Shifting: I love the SRAM Red shifting response: next gear? BAM! I'm there.
- Stiffness: Plenty to spare. Climbing, sprinting, descending, cornering, it's all helped.
- Quiet: No squeaks, no rattles.
- Looks: Black & white, clean.
Dislikes:
- Bars: I want to change the bar angle & brake hood position somehow, but that's adjusting to personal preference and not hard to tune.
- Stickers: I should peel off the stickers on the front wheel. It's not really as labeled anyway - Kinlin rim, Wheelsmith spokes. I just have to find the time to chip off the decals. Unfortunately, they break, they don't peel.
- Red: I'm thinking how I can get rid of the tiny bits of red color. Any suggestions? Black paint?
Cheers,
Damon
Rides great!
Dislikes:
Cheers,
Damon
Damon Rinard
Steel star nuts are 10g give or take a gram. Alloy ones are even lighter though, but not enough to worry about. Paired with a lightweight top cap and alloy preload bolt, 7-8g. Not sure about the cannondale expander, but something like 17 if I remember correctly. You're talking about saving just a few grams. I'd also have to wonder if the wall thickness is the same.
Of course, cosmetic dust caps are lightest, and an alloy steerer doesn't need internal support. That's the main reason to go with an expander instead of a star nut on alloy. I made a plastic dust cap that weights all of 2g(?) that replaces the top cap, the bolt, and the star nut/expander.
[14lb(6.35kg) of no carbon fiber]
[2lo8.wordpress.com]
- in the industry
Hi 2lo8,
Thanks for confirming the 10 gram steel star nut. Alloy star nut? Wow, I've never heard of it. But I think you're right, 2-3 grams savings can't make it high on the $/g list, given I don't even know where to find an alloy star nut! The alloy bolt and thin top cap are tempting though...
Re: Cosmetic caps. I know people ride without the top cap, but I've seen stems walk on the steerer, so I'm keeping a top cap. I want at least a little mechanical connection with the fork. I'll go for alloy bolts & thin top caps, but I won't leave it off.
I think you reviewed a very thin top cap on your blog, right? Got a link?
Edit: Found it. https://2lo8.wordpress.com/2016/05/03/aerozine-top-cap/
Thanks for the tips.
Cheers,
Damon
Cheers,
Damon
Damon Rinard
Carbon top caps are just about as light. I just really don't like 3k weave on parts like that. They're much easier to find though and you don't have to import them. The problem is finding an aluminum M6 bolt for them, which you may or may not be able to find if you have access to a specialty hardware supplier, since there's really not a whole lot of industrial use for aluminum hardware. A lot of the weight savings comes from replacing steel with aluminum, not aluminum with lighter aluminum or carbon.
https://2lo8.wordpress.com/2016/05/03/jl-top-cap/ is better $/g. Half the price but only 1g heavier. Very plain looking though. Looks like the stock dome shaped top caps that are ubiquitous as OEM equipment.
- in the industry
Hi 2lo8,
Good point. I have an FSA carbon top cap, with aluminum bolt, that I can weigh.
Agreed, an aluminum M6 bolt might not be easy to find. Probably easier to buy that J&L top cap, that already comes with it.
Thanks for the link to that. Personally, I like the sleeper look.
Cheers,
Damon
Cheers,
Damon
Damon Rinard
If you decided to get a saddle from Jure Berk you could get a matching top cap as well, I've now had 3, the latest two are revamped as the first one was so thin it distorted, they look awesome and he is so easy to deal with. They are 3g each, so nice a light.
So much to learn from this thread!! Thanks for all the information.
