Parlee ESX Etap
meesterbond wrote:Thanks!
I'll caveat the response re the eeBrakes with the facts that it's only been ridden in the dry and pretty much only on the flat / slightly undulating roads but bearing that in mind, they've been great.
I haven't noticed that the stopping power or modulation is any better or worse than the Red / Record ones I've used previously and they are really easy to adjust (centring and width).
Beautiful bike!
I'm also running eebrakes (centre mount version) right front with SRAM eTap levers.. I had them set up okay with my previous Dura Ace 9000 levers and November Rail 52 rims, but I've now fitted a set of Zipp 202's and the lever 'feel' isn't as good
Please can you tell me how many washers/spacers your shop have fitted between the shoes and the arms (if any)?
I'm not completely familiar with the brakes as I didn't fit them, but it looks like there's just one silver spacer / washer behind each brake pad holder.
It looks great!
I just think it needs higher profile wheels.
Has anyone ever tested the actual aero performace of this frame btw?
kgt wrote:It looks great!
Thanks!
Agreed re. wheels - I had the 303's from a previous build. If I was speccing it from scratch I'd probably go with 404's or more likely Enves and matching cockpit, but they'll do for the time being.
Apparently Parlee tested the frame themselves but I haven't seen any of the numbers. To be honest I doubt it beats any of the true aero bikes out there, but having sold an older model S5 it's a much nicer bike to ride than that.
meesterbond wrote:Apparently Parlee tested the frame themselves but I haven't seen any of the numbers. To be honest I doubt it beats any of the true aero bikes out there, but having sold an older model S5 it's a much nicer bike to ride than that.
I am sure
