2014 Cervelo R5
* UPDATE *
2014 Cervélo R5 54cm Frameset
- FSA K-Force Handlebar
- FSA OS-99 CSI Stem 100mm
- FSA K-Force Seatpost
- Fizik Aliante R1
- Shimano Dura-Ace 9070 Di2 Groupset
- Rotor 3D+ 172.5 Compact Crankset 50/34
- Rotor PF30 BB
- LOOK Keo Blade 2
- 40mm (27mm Wide) Carbon Tubular Rims
- Novatec A291SL/F482SL Hubs w/ Sapim CX-Ray Spokes
- Continental Competition 25mm Tubular Tires
- Fizik Superlight Tacky Touch Bar Tape
- Arundel Mandible Matte Carbon Cages x 2
- K-EDGE Garmin Mount
- Garmin Edge 520
Weight -
Moved some parts; saddle, wheels, pedals, cages over to the new S5. Upgraded the R5 with some lighter components. Contemplating swapping the cockpit out for the same setup I have on the S5, Fizik Cyrano R1 stem, PRO Vibe 7S bars. Also got re-fitted, raising the saddle, rides better and looks better.
Previous build:
- Fizik Aliante R7
- Rotor PF30 BB
- LOOK Keo Max 2 Carbon
- 56mm (27mm Wide) Carbon Tubular Rims
- Arundel Mandible Oil Slick Cages x 2
- Garmin Edge 520
Pretty much stock with the exception of my carbon tubulars which have transferred over from my S3. Going to try my best and ride the bike as is for the season, but will keep my eyes open for possible changes to the cockpit, saddle and crankset.
- Fizik Aliante R1
- Rotor PF30 BB
- LOOK Keo Blade 2
- Garmin Edge 520
Weight -
Previous build:
- Fizik Aliante R7
- Rotor PF30 BB
- Garmin Edge 520
Love the bike..
I have the same frame in a 48cm.
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2015 Specialized SWorks Tarmac Da 9000
2016 Specialized SWorks Tarmac DA 9100
stephenjwhan wrote:[…]- Rotor 3D+ 172.5 Mid-Compact Crankset 52/34[…]
How's the shifting on the setup? Does it really shift an 18 tooth difference? It's always said, that 16 tooth difference is the maximum.
Cannondale SuperSix Evo Disc
Cannondale SystemSix HiMod Disc
@floriansantana
@floriansantana
Thanks @floriansantana it's actually a typo, borrowed copy from an older post of mine. Its actually a 50/34.
And I'll make sure to post the weight asap !
updated w/ new wheels, saddle, pedals and cages
