New Build 2016 S-Works Venge ViAS
What kind of weights are you seeing with the 64's or the 808's? 7160 was with older 404 tubulars, correct? I havent done the Ti bolts you've done but mine with eTap and a fairly light saddle (Tune Kom Vorr....~95g) is right at 7.8kg with 4.5/R45 clinchers, speedplays/cages etc.
7.8kg sounds about right.
Mine is 7.7kg with bell, one arundel cage, speedplay SS pedals, DA11-28, tune skewers, 175mm crank, 56cm. CLX64 clinchers. Everything else stock.
7.2 would need tubular climbing wheels, amongst other things I feel.
And a sweet front light mount thanks to DartanianX
Interesting bottle cage placement.
Sent from my BlackBerry PRIV using Tapatalk
You like it? If youre only going to run one cage that's the spot.
I think keeping the truncated profile of the downtube exposed, as opposed to the alternate arrangement, is better.
Plus the centre of gravity is lower!
Does it make any difference? Probably not, but it's got to go somewhere, and there's different.
I'd say it would depend more on the leading edge you're covering up. Remember, the DT is designed for the wind to be diverted around the bidon, and the ST, if I recall is an aero leading edge, having the bottle there could create more drag behind the DT whilst negating the benefit of the leading edge of the ST.
Weird, I'd think considering components, that I'd have a bit lighter bike overall. Awesome bike though!
- ProfessorChaos
- in the industry
SLCBrandon wrote:What kind of weights are you seeing with the 64's or the 808's? 7160 was with older 404 tubulars, correct? I havent done the Ti bolts you've done but mine with eTap and a fairly light saddle (Tune Kom Vorr....~95g) is right at 7.8kg with 4.5/R45 clinchers, speedplays/cages etc.
I'll weigh it when I get home in a little over a week, I'm on vacation. It was around 7.6kg if I remember correctly with the CLX64's. I have Ti spindle Speedplays which probably accounts for a bit. I'm in Ohio on vacation, and I kind of miss my 404 tubies, as I sold them. I'm probably going to miss them more next week playing in the Smokey Mountains in Tennessee. In Texas though where I live now, the 64's, and 808's do quite well. I want to get rid of the 808's and get some CLX64 tubulars, so I won't have to adjust the brakes when I swap wheels. The 808's are a bit narrower, and it takes a bit of adjustment to get the brakes to work right when I swap wheels.
Yeah, same. Looking for 64 tubbies too as I swap between 4.5's a 64 clinchers. Great looking ViAS, btw.
- ProfessorChaos
- in the industry
Your ViAS is quite nice as well sir. I've honestly just been bouncing my front 808 between the Shiv, and 15 Venge, keeping the rear on the 15. CLX64's with Turbo Cottons, is a rather nice setup, I would love to have the 64 Tubulars though. I'm too lazy to adjust the brakes at the end of the day, so I just roll 16 like that with the clinchers for now. It's a bit heavy, but whatever. I should buy a Red 11-25 Cassette for the CLX too, that is good for a few hundred grams, plus the KCNC Skewers. All those little things help out, I was stoked to find the 118g S-Works Toupe saddle.
tate wrote:7.8kg sounds about right.
Haha, when you said "bell", I was like - "this guy must live in NSW, Australia"
Then I realised we ride the same bunchie Tuesday and Thursday mornings... small world.
I'm the guy on the titanium rig btw.
Great bikes, all of them. Helped in my decision. I'm new on the forum. Just bought everything to build a Venge Vias for me. I love the looks and wanted an aero bike.
The frame arrives this week. I will use Sram Red eTap. Saddle I have a Sworks Toupe. For the wheels I will use for daily training a set of Mavic R-SYS SLR. Not aero at all, but considering that I ride in Rio de Janeiro, if you saw the Olympics you had a glimpse of the nasty climbs and descents we have here. The descents on carbon wheels are not good. Curious to see what will be the final weight.
I will buy a set of aero wheels next for the flat rides, probably the Roval CLX64.
If I can ask what light and mount are you using. Looking for something for my VIAS and this is by far the cleanest setup I have seen to date.
