Kevosinn's personal Cryptic project. Pics up on pg.6
kevosinn
by kevosinn
Thanks Donald! I need to PM you about a few things soon.
Unfortunately AUOC they are actually lighter than your AX brakes haha! They were 124 grams with the cable holders but just the calipers like you posted are 114 grams! Looking at yours I'm sure the construction method is the same. They use a foam core and lay the carbon up over the top.
tomvin90
by tomvin90
loving these steady updates. excited for this one.
natefontaine
by natefontaine
Maybe you could trim off half the threads on the screw and maybe replace the lock nut with nylon nut. That could be worth a few grams and only sacrifices some adjustability.
kevosinn
by kevosinn
Ya that was next on the to do list. Just haven't got there yet. Those are alloy so not sure how much weight I would save but every gram counts. I'm going to continue looking for some AX3000's but I'm not paying $1000 for brake calipers. If I find a decent deal I'll pick them up
AUOC1OC6
Location: Global Citizen but mostly in Australia and Asia
by AUOC1OC6
You already trimmed the Engage to 114g! :shock: How much do you expect to same with a pair of AX3000? 5g? No paint to strip on that one! :wink:
AUOC1OC6
AX Lightness Vial Evo D http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138599
Corima Puma
Giant MCR 2 (retired)
Trek Y Glide Deluxe MTB
kevosinn
by kevosinn
I could save up to 30 grams by switching to 3000's believe it or not. The carbon spring is an interesting option though. I need to pull mine off and weight them. I'm thinking that could save upwards of 8-10 grams off these.
AUOC1OC6
by AUOC1OC6
You mean the AX is less than 100g without shoes and pads? :shock: That's lighter than Fibula.
Anyway, found this in my inventory of spare parts...3g each for your comparison.
AUOC1OC6
Corima Puma
kevosinn
by kevosinn
Another member here has his tuned to 98 grams and that includes holders and all hardware. Only missing brake pads. Thanks for the scale shot! You wouldn't want to sell those would you? :)
xena
Banned
by xena
Yeah the fibs are way heavier than AX but brake much better. I have 2 pairs of old Orion's and you sacrifice a lot of performance for the light weight. I quite fancy some fibs if I do another build but you cannot get them cheap.
I picked up my orion's for pretty good price's on Ebay . The cheapest I have seen them go for is £250.
There are quite a few ax 3000 for sale on ebay right now but expensive and the older orion's are just as light or even lighter.
donald
by donald
I took one more gram off my pad holders so now the total weight for both calipers, with all hardware, including pads and pad holders is 97 grams. On the front I have a very minimal titanium spring that I made and on the rear I have a carbon spring.
kevosinn
by kevosinn
Donald that's a crazy weight for a set with pads and all hardware.....I'm sacrificing a ton of weight over your build there.
kevosinn
by kevosinn
Very excited to announce that I'll be partnering with schmolke carbon on this project. I've always used their bars and this build will be no exception. I'm aiming to do a crazy light bar/stem combo that is under 180 grams.
xena
Banned
by xena
kevosinn wrote:Very excited to announce that I'll be partnering with schmolke carbon on this project. I've always used their bars and this build will be no exception. I'm aiming to do a crazy light bar/stem combo that is under 180 grams.
That's insane :thumbup:
burglarboycie
by burglarboycie
That's going to be the ultimate bar/stem combo!! Schmolke bars are always beautiful so a combo will be insane!!!!
kevosinn
by kevosinn
The bars from schmolke showed up and all I have to say is wow. They really do some beautiful top notch work. These bars come in at an insane 131 grams and are stiffer than several 200 plus gram bars I have laying around here.
