Cervelo R5 VWD 5.85 kg
Cervelo R5 VWD
5.85 KG
Frame: 2012 Cervelo R5 VWD (58cm)
Fork: Cervelo SL
Seatpost: Zipp SL Speed Carbon (27.2 / 250mm)
Seat: Selle San Marco Aspide Superleggerra Carbon
Stem: ENVE Carbon (120mm)
Bar: J2 Velosport (42cm)
Shifters: SRAM RED 10 speed
Bartape: Deda
bottle cages and hardware: Lezyne
Outer Cables: Jagwire Road Pro
Inner Cables: Jagwire
Brakes: KCNC C7
Front derailleur: Ultegra 6800
Rear derailleur: SRAM Red
Crankset: Zipp VumaQuad (175mm 53x39t)
Cassette: SRAM PG90 11-28
Pedals: Time Xpresso 10
Wheelset: Zipp 404 (non firecrest)
Alternate wheelset (not pictured): Zipp 202
Skewers: Nuke Proof Ti twisters
[/URL]
5.85 KG
Fork: Cervelo SL
Bartape: Deda
Brakes: KCNC C7
[/URL]
NeilPryde Bura SL: 12.7 lbs
Cervelo R5 VWD: 12.9 lbs
Cervelo R3 SL: 14.1 lbs
Parlee Z4: 14.4 lbs
Ritte Bossberg 3.0: 14.6 lbs
Colnago C50: 15.2 lbs
Litespeed L1r: 15.3 lbs
Ridley Noah: 15.8 lbs
Ritte Crossberg: 16.9 lbs
Parlee Z4: 14.4 lbs
- arizonahalfnhalf
Very nice! But.... how does that VumaQuad crankset work with BBright??? Thats impossible
arizonahalfnhalf wrote:Very nice! But.... how does that VumaQuad crankset work with BBright??? Thats impossible
not impossible .. I used to have it on my S5 all you need is the correct size spacer, I use a carbon 10mm stem spacer filed the inside to 30mm.
2020 Colnago C64 Mapei-SR12 EPS-WTO 60
2021 Basso Diamante SV-SR12 Disc EPS-WTO 60
2023 Colnago G3X-SRAM AXS Force-Levante
Where there's a will, there's a way! Saved about 130 grams from the Rotor crankset that was on there and I think it's a much cleaner looking crankset on the frame.
Ingredients:
2 Parts Zipp to direct fit BBright adapter & bearing kit (search google for part#)
1 part FSA spacer
1 Part inventive and anal retentive mechanic and voila, a perfect fit
We used most of the Zipp kit (Bearings and 1 of the conical spacers and then used some of the spacers from a FSA kit to get the chainline perfect. Took a bit of trial and error to get the right sized spacers lined up, but it's up and running and smooth as silk.
Parlee Z4: 14.4 lbs
Parlee Z4: 14.4 lbs
- arizonahalfnhalf
Good to know! I tried once on my R5 and quickly lost patience. Looks great though, I love those cranksets.
rorz wrote:Wow that is an amazing weight for a frame that size with no super light weight parts.
How do you like the bottle cage?
Yeah, I try to build my bikes to be light AND functional, so no uber crazy lightweight parts that are too fragile to actually ride (or too expensive to justify). The frame was only 814 grams to start with, so that's an easy foundation for a lightweight build. With my 202's on there she drops down to 5.77 Kilo's.
I really like the cage. While it's no weight weenie part (comes in at about 42 grams) it's got a great grip, with an easy entry / exit. I think it's also a stylish looking cage, which is really the most important part..LOL
Parlee Z4: 14.4 lbs
Parlee Z4: 14.4 lbs
