2015 CAAD10 Black Inc Disc build
medders
by medders
Hi Jeffy,
It would, but the Rotor is effectively a sheath that the 24mm spindle sits in. The sheath keeps the cables flat at the bottom of the shell. The BB30 + shims doesn't cover the Shimano spindle at all, and the cable naturally sits in the middle of the BB shell and rubs on the unprotected spindle. This is only the case for the hydraulic cable - di2 cabling can be tied to the bottom of the shell using a cable tie.
cheers
Medders
jeffy
by jeffy
surprising that they wouldn't account for rub with their own cranks.
DOUG
by DOUG
Hi Lincs (or anyone else with the same frame) i recently purchased a CAAD10 Black inc Disc and was wondering how you routed the rear brake cable? Mine is too long and is rattling around inside the frame so i was going to shorten it but noticed there is no cable guide in the frame for the brake cable. Is this the same on yours? If so did you need to do anything special to stop the cable from rattling like crazy?
Lincs
by Lincs
Hi Doug,
From your question it wold read as though you are routing a mechanical disc cable? I didn't have any issues with the hydraulic pipe for the rear disc brake, I used new pipe and cut it to the length required, it's so rigid it didn't cause any issues other than the routing around the bottom bracket as described earlier in my post. You could put some mini cable ties on it at 8-12" intervals or those c shaped Di2 wiring ties that I used on the Di2 cables and that should do the trick.
Roubaix Pro Disc Race
Haibike Greed RC 29r
Stumpy FSR 29r
DOUG
by DOUG
Thanks for the advice. It is a hydraulic disc brake (SRAM Red22) but i think that the brake line is too long which might be the reason for the rattling inside the frame, i really should get around to shortening it! I have managed to stop most of the rattling by pulling the cable tight and wedging some small pieces of rubber in the cable guide to hold it in place, its not perfect but does stop most of the rattling. After doing some reading i have found a few people with similar issues and they have wrapped the cable in something soft like velcro. The cable tie trick was also a common solution so maybe ill try that first.
superdx
by superdx
Any weights? That's an amazing bike. Disc brakes must really be nice on rainy days and steep descents.
