Ridley X ride 10 cross bike
- Contact:
Thought I would introduce my Ridley cross bike wich I have had tons of fun on this winter..
Frame:
Ridley X ride 10 size 56
Crankset/Bottom Bracket:
Sran force (sadly the drive side pedal tread came loose on the last trip so need a new set of crank arms)
Pedals:
Shimano SPD
Drivetrain/Cog/Chainring/Chain:
Wolftooth single chainring 38T
Derailleurs/Shifters:
SRAM Rival
Handlebars/Stem:
Thomson 120mm X4 stem,Strrtos bars
Saddle/Seatpost:
Thomson Elite post, china carbon saddle
Brakes:
Avid Ultimate Shorty
Front Wheel/Hub/Tire:
Shimano RS11 Schwalbe Rocket Rons
Rear Wheel/Hub/Tire:
8,6 kg as it is here.
Other then a new set of cranks, i need a wider range casette on the rear, the one thats on now only goes to 25, 32 wuld be nice, but I dont think the short cage derailure can handle that, 28 is probably the largest.
Frame:
Pedals:
Shimano SPD
SRAM Rival
Handlebars/Stem:
Saddle/Seatpost:
Brakes:
Lovely! I've just picked up one of those framesets for my son. I plan on using your build as a bit of a benchmark (although I confess that it will probably end up with non - weenie kit such as Ultegra 6600, training wheels etc).
Thanks for sharing
Thanks for sharing
Look 695 aerolight eTap 11
Boardman TTE eTap 11
Brompton S2 LX ti custom
Trek 5500 1994 Sram Red 10
Boardman CXR9.8 eTap 11
Open UPPER - DA 9270
Ridley x-fire Sram Red 10
and lots of non- WW others.
switch to Force 22 cranks (36-46) - you add 150g but versatility ... just is .
Find in net also seatpost clamp with rear brake cable hanger your "solution" look odd...
While ago had '54 X-ride , 7.7kg ( Force22, Rotor crank 36-46 miche super 11, Avid SU, Fizik Antares R3 braided, Rotor 110mm stem, FSA K-force 43cm bar, HED C2 on DT 350 + DT Aerolite/ Campagnolo Eurus 2 way fit , XT pedals.)
Frame & fork are VERY nicely made, however geometry felt ... weird for me. So changed frameset...
Mark Twain
I can be wrong, and have plenty of examples for that
Mark Twain
- Contact:
Thanks for the comments I could not find a force/red crankset at a decent price so went with a APEX crankset, so waiting for that to arrive. regarding the cable for the rear brake, i know it looks odd, but it works. But if I find the correct size, i will get a decent seat clamp with hanger!
- Contact:
Yeah with tubes!
- Contact:
Last weekend I raced a local races called gribben. 75 km of gravel roads mixed with some single track. Had 4!! Punctures, but still had a good time!! Lucky for 2 people to hand out a extra tube!! A few shots of me 425.
My time with out the punctures would have landed me in top 20.. Great fun!
