NeilPryde Bura SL / SR11 (6.32kg and dropping)
Beverly
by Beverly
[869g] Frame: Neil Pryde Bura SL w/ bb guide, cable guides & hanger
[329g] Fork: Neil Pryde Uncut
[059g] Headset: FSA Orbit C-33 No.44E
[003g] Spacer: FSA polycarbonate 10mm
[046g] Bottle cages: Blackburn Slick
[004g] Bolts: Woodman
[477g] Cranks: Rotor 3d+ 175mm 110bcd
[160g] Rings: Praxis Works Forged 36/52t
[109g] BB: Enduro Torqtite PF30
[174g] Pedals: Xpedo Thrust 8 Ti
[087g] F brake: eeBrake (2015)
[085g] R brake: eeBrake (2015)
[00?g] Brake cables: Campagnolo
[038g] Brake pads: Reynolds Cyro Power blue
[103g] Stem: Kalloy Uno 7 11cm
[206g] Handlebar: Edge 42cm
[00?g] Tape: Fizik microtex
[000g] Top Cap: N/A
[009g] Plug: Tune Gum Gum
[011g] Post Clamp: KCNC 31.8
[156g] Post: Hylix 27.2 x 400mm
[105g] Saddle: Merek
[376g] Shifters: Campagnolo Super Record 11 (with inner cables)
[00?g] Shift cables: Campagnolo Super Record
[071g] F Der: Campagnolo Super Record 11
[166g] R Der: Campagnolo Super Record 11
[248g] Cassette: Chorus 12-25
[008g] Lock ring: Chorus 12t
[040g] Skewers: KCNC Ti
[561g] F Wheel: Reynolds Attack/ Tune Mig 70/CX Ray
[614g] R Wheel: Reynolds Attack/ Tune Mag 170/ CX Ray
[241g] F Tire: Vittoria Pave 25c 320tpi
[249g] R Tire: Vittoria Pave 25c 320tpi
[086g] F Tube: Vittoria Ultralight butyl
[086g] R Tube: Vittoria Ultralight butyl
Total: 6.32 kg (13.94 lbs)
AZR3
by AZR3
Always liked the look of the Neil Pryde Bura SL, looking forward to seeing this when its done
jdc5r
by jdc5r
you should try and find these :)
Kayrehn
by Kayrehn
Looking forward to this project. The blue stem and post doesn't really go on this frame but are certainly beautiful in their own right!
Sent from my SM-G900F using Tapatalk
timjerome
by timjerome
very sharp. I actually quite like the blue accents.
Marin
by Marin
Super nice frame, the pic makes me want one
Please! dont put 4-arm Campa cranks or Lightweights on this beauty
CrankAddictsRich
by CrankAddictsRich
I've heard of Neil Pryde bikes, but to be honest, never really paid much attention. This frame has my attention. Very good looking bike.... almost cross between a BMC SLR01 and a Cervelo R5, both of which, I think ,look very attractive.
DartanianX
by DartanianX
This... [OK HAND SIGN]
Sent from my SM-N920I using Tapatalk
These anodized blue components do not match the frame at all IMHO.
Beverly
by Beverly
Marin wrote:Please! dont put 4-arm Campa cranks or Lightweights on this beauty
Too rich for my blood anyways. I'm considering SR11 cranks with Parlee adapter. Or lighter weight FSA/Rotor.
No worries on the blue Tune stuff, they're temporary. Would be nice to have those blue cranks though.
stormur
by stormur
Rotor will be not lighter than CampaSR. Campy cups fit perfectly to NP frame ( NP are made with VERY high accuracy ) , never had creaking in Nazare ( not with Praxis, not with Campagnolo cups ).
Calculate crank+cups/+bottom bracket bearings - then you will get real numbers.
From many Bura images I saw IMO best fit is dark & visually light crank+rings ( Like Campagnolo, Cannondale ... ). DA is visually "heavy" on that frame, same anything with silver rings.
Mark Twain
Beverly
by Beverly
Thanks for that, I never knew about the Praxis bottom bracket. I will have to reconsider the SR11 crankset. Chain ring options are a concern, but likely insignificant.
grnrcr
by grnrcr
I just built up a NOS Bura as well. It's a blast to ride!
Tomstr
by Tomstr
Very nice frame and buildlist! :thumbup:
I'm curious about that rubber worm at the bottombracket. Did you buy it or did it come with the frame. I need a couple of those! :D
Ride it like you stole it
Beverly
by Beverly
It came with the frame. It look like it's apart of the bottom bracket cable guide. The eBay seller said the head tube guide for the rear brake was missing, but it wasn't. NeilPryde will sell you one for $15 though.
Some boring scale shots. SR11 derailleurs, Tune Gum Gum (thanks Fairwheel), and Chorus 12-25 cassette.
Showing up later today are the shifters.
