My new Bianchi Oltre XR1
brahl
by brahl
I really like your bike - great color! I usually only see black Oltres.
2020 Litespeed T1sl
2016 Specialized S-Works Tarmac (SL5)
2006 Trek Madone SL 5.9
jeffsavans
by jeffsavans
Killy wrote:Looks good, can I ask did you have to adjust the clamp to fit the rails?
Thanks. I did have trouble with the clamp fitting the rails. It was just ever so slightly hard to get the clamp around the rails. I ordered the carbon clamp, but it was for rails that were much more oval than the Selle Italia ones. So I gave the original clamp a try again. While tightening the clamp down they do go around the rails. It was a little scary at first, but the carbon clamp was just to open for the rails on my saddle. Everything worked out great.
Killy
by Killy
Good stuff, I have the black ultegra version and for now have settled for the selle italia flow mag rails, for now. Dura ace crankset looks cool too, is this a simple process of swapping from one to another or is there more in involved?
jeffsavans
by jeffsavans
Killy wrote:Good stuff, I have the black ultegra version and for now have settled for the selle italia flow mag rails, for now. Dura ace crankset looks cool too, is this a simple process of swapping from one to another or is there more in involved?
Swapping to the Dura Ace cranks is very easy as long as you already have Shimano cranks which I'm assuming you have Ultegras. Just unbolt the Ultegras and slide the Dura Ace cranks in and tighten to torque specs. Pretty simple. The Dura Ace cranks are a little lighter and stiffer. The chain shifts a little easier over the two rings as well.
superdx
by superdx
Nice bike! I'm considering an Oltre XR too. If you don't mind sharing, what is your height? Noticed your frame is 55cm
Killy
by Killy
Thanks Jeff, since found a crack on the seatpost, this should be fun and a long wait for a replacement.
jeffsavans
by jeffsavans
superdx wrote:Nice bike! I'm considering an Oltre XR too. If you don't mind sharing, what is your height? Noticed your frame is 55cm
Thanks. I'm just over 5'11"(181cm). Some would say I should be on a 57cm frame, but I like the aggressiveness of the 55cm
jeffsavans
by jeffsavans
Killy wrote:Thanks Jeff, since found a crack on the seatpost, this should be fun and a long wait for a replacement.
Killy, I had my bike on top of the car and caught a low branch hanging down in a neighborhood. Got a new seatpost in just a few days so don't stress. Bianchi has a good warranty department (not that it is needed often)
superdx
by superdx
Thanks! I'm about the same height and the fitting guide says 57cm. You are right about the smaller frame being a lot more aggressive. I guess the 57cm is has a bigger head tube?
jeffsavans
by jeffsavans
superdx wrote:Thanks! I'm about the same height and the fitting guide says 57cm. You are right about the smaller frame being a lot more aggressive. I guess the 57cm is has a bigger head tube?
My suggested size is a 57cm as well. But it depends on what you're wanting to do with the bike. If you're racing it a lot and are pretty flexible, you can go to a smaller frame. The 57cm has a taller headtube and a longer toptube. With the smaller frame I can run a lower stem and make up the reach with longer stem. Just makes the bike more aggressive, lighter, and stiffer. Of course don't over due it. Some pros run bikes 2 even 3 sizes smaller than their "suggested" size. I would not be able to do so as it would hurt my back and make it more uncomfortable to ride which relates to being slower. You have to find the perfect fit for your intentions on the bike.
Killy
by Killy
£140 and a two week wait I feared worse, comments appreciated Geoff :thumbup:
tlmsal
by tlmsal
Love the looks of this bike. I bet this bike crushes some of those SC roads
superdx
by superdx
Thanks for your reply, very helpful! I'm glad you found the perfect fit for you.
I don't race but the group rides in my area are pretty intense. Climbing is almost 90% of the rides, maybe that means a slightly larger frame is (maybe?) more stable and better power output as I will spend not any time in the drops.
BlueberryCake
by BlueberryCake
Beautiful Bike! :wink:
zirxo
by zirxo
Love the bike!
