It is currently Thu Jan 18, 2018 7:12 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page 1 2 Next
PostPosted: Thu Feb 11, 2016 3:55 am
Starting a thread to cover my build of a Trek Madone frame. This will be replacing . The goal is to get the bike lighter, and a bit more "racy".
The donor bike is my 2010 Specialized Roubaix Elite SL2. The only thing left stock on the bike is the frame. I'll be stealing almost everything.
The "new-to-me" frame came from ebay, with some parts on. 58 cm H1 standard paint, minimal graphics. Blacked-out logos. Ugly Trek "chrome" head badge removed (1.1 gram saved :D )
I will update the parts list (removing the question marks) as I go. All weights are in grams.
980 . . Frame (stripped, with der hanger, and all cable stops installed)
33.5 .. Cane Creek headset top (including bearing)
21.8 .. Fork lower bearing
375 ... Fork (includes the thing inside at the top. Feel free to let me know what that is called)
7.8 . .. (2) stem steerer spacers (Bontrager)
10.2 ...Chain keeper (factory)
7.6 . .. fork cap (and bolt)
109.2 .Stem
87.5 .. Ultegra front derailleur
211 ... Ultegra GS rear derailleur (mid cage)
148.4 .Dura Ace integrated front brake (includes mount bolts)
130.8 .Dura Ace integrated rear brake (includes mount bolts)
6.6 . .. Rear brake adjuster/QR
18.7 .. Bontrager Duotap (chainstay integrated) (I don't even know what this is, yet)
450 ... Crankset (drive side) (FSA K Force Light MegaExo 24mm spindle)(50/34)
150 ... Crankset (non drive side) (FSA K Force Light) (when Stages is not used)
226 ... Stages Energy crank arm
43.8 .. BB bearings and seals FSA BB90-to-24mm MegaExo
110 ... No name carbon saddle
149 ... Bontrager seat mast cap 175mm
252 ... 11 speed chain (Ultegra)
22.8 .. Rear wheel QR
20.7 .. Front wheel QR
660 ... Vuelta Corsa Lite front wheel
875 ... Vuelta Corsa Lite rear wheel
388 ... Tires (2) 4ZA Cirrus Pro 23mm
185 ... (2) Vittoria Ultralite tubes
250 .... Cassette (11-28 11sp Ultegra)
32 ..... Bottle cages (2) (no name carbon)
4.8 .... Bottle cage bolts
6.7 .... SRAM Cable barrel adjusters
225 .... Pedals - Nashbar Alpe D'Huez (Keo style)
365 .... Dura Ace 9000 shifters (184.2 Right, 181.3 left)
245.5 . Carbon no-name bars
155 .... cables and housing (estimate weight from previous build)
??? .... SRAM Garmin mount
64 ..... bar tape
Trek Madone 7.9 58cm 14.9lbs
PostPosted: Thu Feb 11, 2016 4:20 am
It's an integrated speed/cadence sensor that fits into the left chain stay.
2015 Trek Emonda SLR Project One - Red eTap - Zipp 303 - 6.48kg
2016 Cannondale SuperX Rival CX1 - 9.29kg
iRide4Sue.org Please Donate to fight Cancer. $27,000 raised in 2017
PostPosted: Thu Feb 11, 2016 7:16 am
Strangely, mine's a little heavier.
Do post pictures of the frame soon!
Trek Mad-one 7 Series team colours http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=115500&start=15
Fuji SL 1.1 http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=140134&hilit=Fuji
PostPosted: Thu Feb 11, 2016 5:19 pm
Thanks. I'll be updating the thread with pics.
The frame was a lot heavier than I expected, with the 2013 bragging claims of 750g frames. Maybe they were weighing 53 cm bikes.
PostPosted: Thu Feb 11, 2016 10:59 pm
Trek's claimed weight was for a 54 Madone H1 with the U5 Vapor coat. You didn't specify what size frame you have, but the 7.9 has a standard paint job, which is heavier.
PostPosted: Fri Feb 12, 2016 12:18 am
Thanks. I'll add the info to the first post. This is standard paint, H1 head tube, 58cm size.
PostPosted: Fri Feb 12, 2016 7:08 am
OP Duotap is the version before currently version. (oldnslow2's picture)
PostPosted: Fri Feb 12, 2016 10:03 am
Looking forward to this one because of the frame size.
My ex bikes:
TREK Madone 5.9 SL
COLNAGO C50 nl12
PostPosted: Fri Feb 12, 2016 12:32 pm
Me too. I actually got a deal on Madone H1 60 and that frame will replace mu current Emonda SL 56. I hoped the frame would weight around 900 grams, but I think I will get lucky if it would be just under 1000 grams. Please post photos!
Trek Madone 7s 60 H1
Trek Emonda SLR H1 Campy Record
PostPosted: Fri Feb 12, 2016 4:52 pm
Here's a couple of in-progress pics. The first is the frame. This isn't fully stripped. It has the der hanger, cable sleeves for derailleurs, and the cable guides where the cable outers terminate. For bragging rights, these could be removed, but the frame is useless without them, and there are no lighter-weight alternatives. I guess I could pull the cable sleeves once the cables are in place.
Unhappy donor-bike can be seen awaiting his fate.
The next is the current state of things. I need to find my hanging scale.
The stem placement isn't the end-goal. I'm using that position to set up the cable length, giving me the greatest choices for fitting as I get it on the road.
I'd have probably been well-suited to H2 geometry, but that's not what showed up on eBay. At my age, there's a good chance this will never get slammed. Well.... I'll certainly try it, but probably won't keep it that low.
My Roubaix was as low as I could get it, with a stem that was angled down a little. With this frame (set up as in pic) the bars are about 1cm lower than the bars on the Roubaix. I should have a decent range to work with, with the spacers and stem angle choices.
PostPosted: Sun Feb 14, 2016 1:41 am
Progress day. I'm going to get a different stem. This is the one from my Roubaix, and I don't think the angle is going to work for me.
As it sits, we're hovering at the 15lbs mark. From a personal-desire standpoint, I need to come in under UCI limit. :mrgreen:
Still waiting for the 7x10 rail clamp for the seatpost.
The best news of the day.... the Stages power meter clears. Barely. About 1.5mm.
PostPosted: Sun Feb 14, 2016 11:00 pm
Adding a weight pic. I only have hanging scale for pounds, so no kg display. Depending on what bar-tape I switch to, i think I can get under UCI limit.
This is ready-to-ride, with cages and pedals.
PostPosted: Tue Feb 16, 2016 3:21 am
Placeholder for uploading pics
PostPosted: Tue Feb 16, 2016 3:23 am
2nd Placeholder for uploading pics
PostPosted: Tue Feb 16, 2016 3:24 am
3rd Placeholder for uploading pics
There are no new unread posts for this topic. Trek Madone vs. Trek Emonda decision
[ Go to page: 1 2 3 4 5 6 ]
Ahillock
76
10470
Tue Aug 08, 2017 3:35 am
Ahillock View the latest post
There are no new unread posts for this topic. The Trek Madone 9
Bely
19
3927
Sun Oct 22, 2017 8:28 pm
stax View the latest post
There are no new unread posts for this topic. trek madone 9 updated
markyboy
12
2113
Thu Aug 31, 2017 5:03 am
markyboy View the latest post
There are no new unread posts for this topic. Attachment(s) 2017 Trek Madone 9
FIJIGabe
28
11481
Mon Aug 21, 2017 4:43 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. Attachment(s) Trek Madone 9 2018 H1 P1
pratt
20
3780
Thu Sep 14, 2017 7:05 am
TonyM View the latest post
Users browsing this forum: Bing [Bot] and 9 guests
