Look 795 light
- in the industry
- Contact:
Well I have it now. There are many design features I like about this bike. Firstly the stem that is flush with the top tube but then there are the details. The stem is adjustable and by flipping it you get a different range of movement. If however I have picked the wrong stem getting a new one will take 6 weeks or more and a lot of coin. I have gone for a 130mm stem
The crank set (ZED3) is a one piece affair with a 65mm diameter crank axle. Bearings are propriety press fit. There is a locking collar on the NDS to preload everything. A simple design and effective. The cranks can take 110mm or 130mm BCD chainrings. The pedal thread inserts can be inserted three ways to give you 170mm 172.5mm or 175mm crank length. Now why are not all cranks made this way?
The seatpost mast insert has elastomers for extra comfort and the clamp can accept monolink or standard saddle rails. There is case with this frameset with a cutting guide for the seat mast a bunch of ferrules, chainring bolts and spacers and Look bar tape. They have installed cable casing from the factory. Look have tested every casing on the market and found Jagwire Road Pro to give the lowest friction. This is the detail I like.
I got a good deal on the light frame so this is why I have gone for it over the aero light.
As I have a pair of Record 11 speed brakes in a box I have got the 2015 Campagnolo Record 11 speed Ergo's and mechs to fit.
Bars will be the Look aero when they arrive.
Wheels will be a set of 23mm wide 38mm deep carbon tubular rims (BORG38 I call them for want of a better name) laced to White Industires T11 hubs 20F/24R with Sapim CX-rays.
I am thinking about running a SRAM 11 speed cassette because these are very light and steel. Chain will be KMC or Campagnolo.
I will use a berk saddle.
- tomyboy123
Excellent, that would be my color chose to.
Well, don't get carried away...
They use Jagwire simple because, there housing colors are matching perfectly with the colors of the frames they produce.
http://jagwire.com/products/v/road_pro
Sadly, the quality of the CGX,KEB and LEX housing is far from excellent. Lately, I have to replace LEX Shifting Housing on different bikes, due to cracking-splitting ends, after just one sezone.
Housing is just to hard, mauch better choice would be Shimano OT-SP41, but you don't get those pretty-maching colors.
Cabelas on the other hand are OK. You should maybe try new Jagwire Road Inner Wires - Elite Ultra-Slick
http://jagwire.com/products/v/shift_inn ... k_uncoated
Quite expensive, even compared to Shimano Polymer, 17 EUR per cable...
http://www.bike24.de/1.php?content=8;pr ... ,4,167;mid
Looking just from styling perspective, 38mm on this flat frame would me littly low. From this perspective, 40 c are just too skinny for this frame.
http://cdn.mos.bikeradar.imdserve.com/i ... 60-540.jpg
Looking like a guy with big upper body and and skinny legs.
Minimum 50mm is perfect for 795, but if you already have them, there is no other way.
Wish you a nice build and good choice Light over the AeroLight
bm0p700f wrote:They have installed cable casing from the factory. Look have tested every casing on the market and found Jagwire Road Pro to give the lowest friction. This is the detail I like.
LOOKing good
The Look decal is a little understated, but the whole package looks fantastic!
Sent from my SM-G900F using Tapatalk
So, so nice.
- in the industry
- Contact:
Bars have turned up. Build will start next week. Berk is doing a leather covered saddle with yellow fluro stitching.
gone for a SRAM Red22 11-26T cassette.
The bars weigh 272g so not light but hey ho plenty of other bits are.
