Luncheon's Tarmac SL3
Thanks frankie!
Ended up with the praxis adapter (sorry Bart!)
Collected the frame back today. Must say I'm pretty stoked.
The blue is not exactly Sl5 (new tarmac) chameleon purple but it's fine. Still love it!
Great glossy paint job on the 3t team stem
Original sworks carbon seatpost is mighty heavy. 27.2mm x 300mm (cut) with bolts n cradle.
Sent from my SM-G920I using Tapatalk
Before makeover:
Post makeover : [emoji2]
Just got the bike back from the shop. Height of seatpost and fore aft of saddle is not adjusted yet.
Current weight is 6.48kg. Dang.. And I thought it was easy to drop down to 6kg...
Phase 1 completed. Let's get some miles in before modding further.
Installed a token chain catcher. 7g.
Bb30, compact rings, 165mm
In comparison, the SR (with rings) weights 648g, and rotor 3d30 (without rings) weights 550g.
Weight of the stock red rings
Picked up this to match my planned sram red crank. (I happened to have both campagnolo freehub and shimano / sram freehub for my wheels)
I didn't. That was something I ought to have done - comparing the weight before n after. My guesstimate is that the paint would add on about 200-250g, which is still acceptable to me as I can always drop weight elsewhere (within reasonable cost).
- ProfessorChaos
- in the industry
That looks fantastic. Great job!
Stronglight rings vs red rings : -17g
A bit disappointed with the weight of the stronglights
mantra fx carbon vs slr s1 : -23g
Did a short loop nearby with some short climbing segments in between. Lovin the ride so far.
I'm having difficulty sourcing for 165mm sworks cranks or 165mm campagnolo 30mm spindle cranks, and ended up using sram red crank as it looks good, are as stiff and light and more importantly they are easily available. Paired the red crank arms with stronglight rings for its marginal wt savings and nicer rings (to me). Oh - I got the crank arms painted black, with sworks sticker under the lacquer... Yes, I'm gonna get some stick for the sworks sticker...
Let's see if these 165mms make much of a difference over my regular 170s.
Added red 22 cassette as well. And changed the record 11 chain for the cheapest kmc chain I can find.
With this, my planned phase 2 is completed. I need to get more miles on the bike, get the fit dialled in, and ride some more. Perhaps get a shorter stem (90mm)....
A recap so far:
Phase 1
"heavy " painted sworks sl3 frameset
Full SR 11 components
Stock seatpost
C260 stem
Zipp contour sl carbon bar
Easton 24mm tubs
6.48kg
(done)
Phase 2
Swapped cassette to red 22 (153g vs 200g, -47g)
Swapped crank to red 22/stronglight (494g vs 647g, -153g)
Take out praxis adapter (-97g)
Add in enduro zero ceramic bearings (+57g)
Swapped mantra fx carbon for selle italia slr (122g vs 144g, -22g)
6.22kg (dropped 260g thereabouts)
(done)
Planned Phase 3 mods
1. Tune u20 skewers (20g vs 120g, -100g)
2. Tune whatshisname (water carrier) 2.0 cages x 2 (11g x 2 vs 0, +22g)
3. Tune stuck zero offset seatpost (90 vs 186g, - 96g)
4. C260 alloy stem with ti bolts (105g vs 100g?, -5g?)
Planned phrase 4 mods
1. Sub 1kg tubs (-200g)
2. Ee brakes (-120g?)
Happened to have a spare Garmin 500 lying around, so took the opportunity to weigh it.
Left: 500
Right: 520
Left: 500
Right: 520
With fulcrum racing speed 50 @ 1.36kg
Bike wt : 6.38 ish kg.
Finally got me some bottle cages
Heavier (18g) than the tune bottle cages, but nicer.
Pick up this recently
Super six hi mod
Red 10 speed
Osymetric rings
P2m rotor 3dplus
Fulcrum racing zero
Deda super zero carbon seat post
3t team stem
Fsa team issue carbon bars
Selle italia saddle
The plan is for this to be a wet weather bike + trainer bike.
Super six hi mod
Red 10 speed
Osymetric rings
P2m rotor 3dplus
Fulcrum racing zero
3t team stem
Selle italia saddle
