Project: English 2
Yossarian
by Yossarian
My previous English build is still going strong but being quite a big frame and with an integrated post, it's a pain to travel with...
So Rob is building me something new.
His folding road concept frame plus...
Enve Gravel fork
eTap
Mechanical discs (with routing clearance to replace with eTap hydraulic at a later stage)
Enve M50 / Chris King
various other nice things, and a fancy paint job from Color Works
Something for the road less travelled...
romalor
by romalor
if I may suggest two things ! :)
1) go with center lock hubs , chris king will have some available soon or the white industries CLD are available
2) I wouldn't go for mtb M50 rims , but for 35 mm high something more roadish cyclocross and maybe from another brand... they are good options unless you only want enve rims :arrow:
shlammed
by shlammed
i agree with centerlock hubs.
I was a non believer until I used a centerlock disc. it works so much better.
will be a nice build.
Grill
by Grill
When's the delivery date?
shlammed
by shlammed
get the frame built with hydro guides for rear brake line (unless its full housing internal routing). it will be nice for when etap comes in hydro and you upgrade to not have to redo the frame if you have normal cable stops.
going through that now with my custom tandem that I was going to retrofit di2 hydro to. (im building a new frame now for that)
CBJ
by CBJ
This sounds like an amazing project. There are also the new Stans Avion wheelset.
Yossarian
by Yossarian
Sorry guys - I had almost forgot about this thread!
The frame is all set up for internal brake routing, and the plan was always to allow space for hydraulics once SRAM release the eTap Hydro.
Centrelock hubs never occurred to me actually. Perhaps I'll have to try some out at a later date.
Rob's going to be taking it to NAHBS in all its technicolour glory, although possibly not in its final guise as the eTap hasn't arrived yet...
Yossarian
by Yossarian
And here are the wheels...
CBJ
by CBJ
Schwalbe S-One Tubeless? If so have you ridden them yet? Running them tubeless?
Yossarian
by Yossarian
No - G-One 35mm tubeless actually. I've not ridden them yet - they're in Oregon and I'm in the UK!
CBJ
by CBJ
G-One of course I did think they looked bigger than 30mm
AZR3
by AZR3
Damn it, that's going to be sweet!
:popcorn:
BmanX
by BmanX
This is going to be good.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
Yossarian
by Yossarian
It has some pretty awesome fading...
And some very green green.
