FL's STORCK AERNARIO G1
Very nice build. Did you get a chance to weigh the frame and fork? If so, would you mind posting (along with frame size)?
Thanks -- decent weight, specially for the fork. Contemplated on a Fascenario 0.6 several years ago as i was intrigued by the integrated THM front calipers.
Classy build! I would love to build something like that where "most stuff came from my previous builds". The black chain really matches the rest. Does it stay black over time or do the paint wear off like on black chainrings?
Current:
S-Works SL8 RTP (build in progress) | Diverge Comp Carbon
Retired:
S-Works SL7 | S-Works Venge | Ultimate CF SLX Mk IV | Ultimate CF SLX Mk III | S5 | R3 | Cento | ...
Retired:
- Contact:
@ill principe, thanks. since I installed one on my aeroad, haven't really noticed it wearing off as much as chainrings do.
I would also guess that the areas where they wear off, becomes filled with lube residue so it stays 'dark'.
you cant buy fitness, but you can buy advantage.
- Contact:
some of the minor mods I did.
when I acquired the frame it had 9mm holes for wires, too big for the shimano grommets.
got 9mm blanking rubber grommets for cars, cut the wire path, problem solved.
seatpost.
stock alu cradle
carbon cradle from an unbranded post I had.
seatpost.
stock alu cradle
