mnmasotto wrote:Do the pedal inserts make any noise?
If not assembled correctly, this crank and bearings could be nightmare.
You have to use Shimano Anti Seize grease on outside of the female chainring bolts, where is contact with carbon. You also have to put this grease around and in the pedal inserts. Do this and you are 100% free of squeaking sound, that may be generated from this part of the crank.
Rixter great 695 and pleeeeeease, take some proper photos and to this beautiful 695 justice...
