Cryptic cycles
Thanks a lot Donald! I appreciate the kind words.
Here's a quick picture of a frame lay up around the head tube. It's very important to keep the layup clean and uniform. It limits the sanding needed and allows for a stronger and lighter junction. Every frame I build has a different layup around the junctions. Fiber orientation, the amount of layers and the type of material are designed unique for the riders needs.
Thanks for the kind words Brandon I appreciate it!
I've been hard at work on a bunch of new products and frame improvements. The Cryptic Cage will be available very soon. This is a prototype I pulled off the mold today. This is 100 percent unfinished and raw so keep that in mind.
IMG_2644 by kevosinn, on Flickr
Thanks guys! Im pushing to have the weight around the 15 gram range.
Yes @jooo Its laid up around the mandrel then vacuum bagged.
Finishing up a new frame. Here is the BB lay up and seat tube layup.
IMG_2558 by kevosinn, on Flickr
IMG_2553 by kevosinn, on Flickr
I should be done with it in the next few days and I'll post pictures then. Went out and took a few night shots of another bike also.
IMG_2664 by kevosinn, on Flickr
HA! good catch on the spoke....i'm admittedly not the best with photoshop.
As far as the downtube size its not as small as it looks in the picture but its smaller than the trends of massive tubing today. This bike was going for a more traditional look. The good thing is that even tube diameter is considered when I build a frame and can be changed according to the riders needs.
