Cryptic cycles
kevosinn
by kevosinn
Figured I would start a thread on what I've been working on.
All frames start with a cad drawing done with bike cad pro. It allows you to see exactly the proportions of the bike before it is built.
ImageIMG_0166 by kevosinn, on Flickr
Next it's decided on the ride quality, stiffness, style or riding, weight goals etc. and tubes are then created. A mix of several different carbon pre preg materials are used.
I'll post some completed pics and more of the process in the next few days.
danbjpa
by danbjpa
Nice to see one more WW member framebuilder! more light development to us. Congrats and sucess!
The fork will chosen based on geometry/ride/style of customer or will a fixed model/geo?
Enviado do meu iPhone usando Tapatalk
FastDad
by FastDad
Nice to see a special thread dedicated to your frame builds.
I like the mix of different textures...unfortunately I will never be able to purchase a frame from you
Please post as much as possible pictures from the progress and processing
kevosinn
by kevosinn
Thanks for the kind words guys. I use enve for most forks but I can build a frame to work around any fork. I'm going to offer 3 standard layups and then an option for fully custom layups as well as geometry.
mythical
by mythical
I'm liking this thread already! Just keep them pix coming, Kevin! :popcorn:
What BB shell ‘standard’ are you gonna use for your first frame?
“I always find it amazing that a material can actually sell a product when it’s really the engineering that creates and dictates how well that material will behave or perform.” — Chuck Teixeira
RideWert.com
Wert Cycling on Facebook
kevosinn
by kevosinn
The first frame is getting bb86 but I just made all my own tooling to be able to do bb86, English 68mm and pf 30 and bb386.
kevosinn
by kevosinn
Machining new fixtures for BB shells on the lathe.
Clannagh
by Clannagh
Great thread, I love all this stuff. I modded my own English threaded BB to a PF30. Did you know there's actually an off the shelf carbon tube available with correct internal diameter to accept PF30. Just a thought to save on some tooling :thumbup:
xena
Banned
by xena
Brilliant thread and Kevin is giving us a real insight into custom frame building. :thumbup:
kevosinn
by kevosinn
Thanks! Yes I have found a few places that I could buy pre made tubes from but I own a lathe and mill so making molds and tooling is not too bad! It allows full optimization of all the parts on the bike
nicrump
by nicrump
Clannagh wrote:Great thread, I love all this stuff. I modded my own English threaded BB to a PF30. Did you know there's actually an off the shelf carbon tube available with correct internal diameter to accept PF30. Just a thought to save on some tooling :thumbup:
more importantly the CTE of an aluminum mandrel will make specifying the mandrel OD to produce an exact 45.97mm ID carbon tube very challenging. Its not just the size, thickness/mass of the tube but also temp, dwell of the cook and to further complicate, what kind of and how much carbon in what orientations followed by compaction method. my solid stainless PF30 mandrel went back to a professional grinder 3 times before getting it to a less than 25% reject rate on BBs shell ID. that was after thorough calculations.
you'll get there.
kevosinn
by kevosinn
you'll get there.
Hey thanks for popping in! I sent you an email back last week did you get it?
And yes it's taken me several test runs with multiple materials to get something I'm happy with. I knew thermal expansion would be an issue so I slowly brought the mandrel down to a size that worked well. Stainless is working the best as you said. And I've tested several different layups after I had one that worked size wise. Talk soon hopefully!
nobuseri
by nobuseri
Nice work; subscribing to this thread. :thumbup:
2016 Cervelo R5 (Red 22)
Pegoretti Responsorium (SR11)
SuperSix Evo2 Hi-Mod (Force 22)
jooo
by jooo
Clannagh wrote:Did you know there's actually an off the shelf carbon tube available with correct internal diameter to accept PF30
[s]From which supplier?[/s]
edit: didn't have the thinking cap on, there's actually a bunch of places that sell 46mm ID tube that should work for PF30 BB's.
I have actually been looking for a webshop selling 44mm ID tube in small amounts... A quick search only seems to find cheap Chinese tubes from eBay/alibaba as far as I can see?
nlouthan
by nlouthan
That's so cool to see. How do you actually build the tubes?
