Focus Izalco Max Project
Hello everyone.
My frame finally arrived, so i think its time to start a new topic i will be aiming for a sub7 ride for now.
I love the frame colors so today i went to take pics. Soon i will post a list of the components!
Frame:
Saddle and Cranks:
Hope you guys like (i do )
John
Frame:
Saddle and Cranks:
John
Wheels Supra RFC 55 with: Pro-lite Skewers, Continental GrandPrix, Michelin
tubes and garmin speed sensor and Sram PG1070 11-28t Cassette - 2,700g
K-Edge Combo Mount (no camera bolt) - 43g
NoBrand Full Carbon Saddle - 110g
3T Rotundo Carbon - 198g
Fizik Bartape SuperLight (not cuted yet with bar ends) - 82g
Fsa carbon Headset Cover - 10g
Sram Force 2013 Front Derailleur - 89g
Sram chain kepper - 6g
Sram Force 2013 Rear Derailleur - 162g
Sram Force 2013 Calipers with BBB Carbon brakepads - 288g
Sram Force 2013 Levers - 272g
Sram Force BB30 Crankset - 495g
PF30 bearing and washers - 55g
Stem Fizik Cyrano R3 100mm -7degres - 135g
NoBrand Bottle cages with alu bolts (Pair) - 25g
NoBrand seatpost clamp - 10g
Rotor Q-Rings 52t&39t - 143g
Powercordz brake kit Front and Rear (not cuted yet) - 86g
Powercordz derailler kit Front and Rear (not cuted yet) - 67g
Prototype Chainring Bolts x 5 - 8g
Focus Izalco Max 2014 Fork (not cuted) - 313g
Focus Izalco Max 2014 Frame with Rear and Front Derailler Hanger - 716g
FSA K-Force Light 27,2mm with 25mm recue (cuted) - 159g
Sram Force Hoods Black - not owned yet
Pedals - not owned yet
Chain - not owned yet
Garmin 800 with silicone protection - 110g
Garmin Cad/Speed Sensors - 27g
Ritchey Headset Semi-integrated 1 1/4" 1 1/8" - 63g
AbsuluteBlack Top Cap - 4g (not owned yet)
Extralite Ultrastar 3 Expander - 6g (not owned yet)
That's shaping up nicely.
Looks awsome! Looking forward to The final build!
I really like the frameset. The location where you shot the picture in the first post was a great choice as well. Are you planning to mask off or remove decals from things to match the yellow? the seatpost already stands out with its red stripe. I like that you listed all the weights as well.
Thanks Euph, i did put some effort in this (my first) build! About the seatpost i will sand it down so it will have the same look as the saddle but i run out of sandpapper 400 I rode 20k each way on my old Cx Singlespeed bike with the frame in my backpack to make that shot
- Samuel Sanchez Gonzalez
If it's your final saddle and front end setup it will look awesome once finished
Nice,
good proportions
I like how you've got your levers adjusted on the bars, makes sense to have flat transition on the tops and the levers are easily reachable from the drops
good proportions
