2016 Giant TCR Advanced SL
I'll post photos tonight, but I felt that I needed to share the info. I was running a white 2014 TCR Advanced SL and just shifted to a black current model, and saved a whopping 380g (or there abouts). Based on write ups the new frame was 180gish lighter. Did the 200g come from the white paint?!
Frame weight, without headset
Also for those wondering, the new ISP topper weight is now just 113g, from 160g (if memory serves me right). Good job Giant.
Frame: 2016 Giant TCR Advanced SL
Groupset: SRAM Red22
Pedals/Power Meter: Garmin Vector S
Handlebar/Stem: Giant Contact SLR
Saddle: Specialized Toupé S-Works
Bottlecages: Bongtrager RL Cage
Wheels: Reynolds Assault SLG
Tires: Continental S4000II 25mm
Garmin Mount: Raceware Garmin out-front
Weight as photographed: 6.66kg
2018 Giant TCR Advance SL0 Disc
2017 Festka Scalatore
1989 Battaglin Roche
1985 Alan Carbonio
1985 Alan Carbonio
Very nice. I do like the look of these frames
On a bit of a side note, how wide to those tires blow up to on those wheels? I've got the exact wheels, but deciding weather to go with 23mm or 25mm GP4000's
gravity wrote:What size is that?
It's a medium
awjpca wrote:Maybe the write-up weight claims are from a different sized TCR? The excess 200g weight savings can't just be a different paint job.
Thanks! The difference is probably just from the paint. I was happily surprised with the weight loss
thewallace wrote: how wide to those tires blow up to on those wheels?
I'll take photos soon. I'm running 25mm. Side clearance is fine, but the tire height comes close to my front brake. I fear that if narrower rims were used, it would pinch up the profile of a 25mm and snag on the front brake
upside wrote:Let us know how much different the 2016 rides compared to your other
Thanks! Despite the weight loss, it rides smoother over chipseal roads. Stabilty hasn't changed compared to my 2015. I haven't done enough climbs on it. Gimme a few more weeks.
burglarboycie wrote:Very nice. I do like the look of these frames
Thanks!
1985 Alan Carbonio
1985 Alan Carbonio
Bit of good news and bad news:
Bad News: Was planning to have my handlebars painted black to match my new frame. I had a crash a few months ago, but since it was a slow one I brushed it off and assumed that it was fine. Unbeknownst to me there was a crack when I removed the bar tape. Thankfully it didn't fail on me during a number of races.
I was going to use a friend's cockpit while I was supposed to have the bars painted, so here's the weight of a Connect SL 110mm carbon with 42mm Connect SL handlebar (just for weight reference)
Two Piece: 447g
I ended up getting the new one-piece cockpit in matte/gloss black, the very same one I wanted my old one to look like
Good news: The new Giant Contact SL one-piece is lighter than the older one
New: 352g
Old: 367g
Two Piece: 447g
New: 352g
Old: 367g
1985 Alan Carbonio
1985 Alan Carbonio
jeffy wrote:do you know the weight of the Connect SLR 110mm carbon stem?
My Contact OD2 SLR 110mm stem weighs in at 134g
9734344 wrote:Frame weight maybe less headset but is including rear stay protector/spacer.
Worth 20 or 30 gr
Current bikes:
Scott Addict Premium Disc 2018
Scott Addict Orica Greenedge 2015
Retired:
Canyon Endurace CF SLX 2016
Canyon Ultimate CF SLX 2013
Retired:
