The FIELD Cycles
btompkins0112
by btompkins0112
So hawt!!
Lighti
by Lighti
It Looks so perfect
Gesendet von iPhone mit Tapatalk
drchull
by drchull
Looks beautiful.
Envious.
phips
by phips
Bely, that is a beautiful work of art! One quick Q - how have you found the THM Fibulas? Ever ridden EEs and can compare? Or even in comparison to standard Campag SR? Thanks!
Bely
by Bely
@phips, the brakes aren't as good at the ees (which I use on the speedvagen) I feel best weight to stopping power and setting up is still the EE.. I got the fibulas kind of just for weight. hope this helps!
Current
Festka Scala | Pego Respo | English V3 | Colnago EPS Erik Zabel | Colnago V4rs
Incoming
prendrefeu
by prendrefeu
Care to tell us about that handlebar/stem combo?
andyindo
by andyindo
prendrefeu wrote:Care to tell us about that handlebar/stem combo?
Looks like a repainted PRO Stealth bar to me...
prendrefeu
by prendrefeu
410g. Yeesh. :shock:
Bely
by Bely
It is.. But of all the integrated ones - I like the looks of this the most! Any other recommendations?
Current
Incoming
prendrefeu
by prendrefeu
Since you've got the funds (just guessing based off of your recent stable acquisitions), why not go for a custom combo? That way you get the handlebar shape you want + the stem you want, custom set (Berk can do this if you're in Europe, Kevin @ Cryptic for North Americans)... and it will be at least 100g lighter, if not more.
Haero 155g handlebar + Enve stem (~130g, estimate) will probably come out to ±260g as a combo. You lose some weight by not having the bolts/faceplate :)
Then paint to match.
Anyway, it looks sharp and as long as you are happy that's what matters most!
phips
by phips
Bely wrote:@phips, the brakes aren't as good at the ees (which I use on the speedvagen) I feel best weight to stopping power and setting up is still the EE.. I got the fibulas kind of just for weight. hope this helps!
Indeed it does! Thank you. I run EEs on a Parlee at the moment, but am contemplating a new build (Argonaut too, actually) and was pondering THMs. I shall stick to the tried and tested, albeit V3, EEs then.
Cheers
Bely
by Bely
Current
Incoming
Bely
by Bely
Since there have been some requests for matching wheels...
Current
Incoming
Denavelo
by Denavelo
Compared to your speedvagen, how does the Field ride?
I have a speedvagen and Field is kind of on my radar.
Rob English "Mudfoot" 29er | Focus Izalco Max | Firefly #194 Stainless XCR | Firefly #277 | Neilpryde Bura SL 11.9 | Crust Evasion Lite
majklnajt
by majklnajt
Very nice proportions of this bike!
Like it much more with Meilenstein wheelset.
