Specialized Allez Race, E5 Smartweld, anodized gold, GOOOOLD
Birdman
by Birdman
Specialized S-Works crank, 170mm
Praxis 48/36 rings
554g
Cervelo R3 MUD ~ viewtopic.php?f=10&t=136544
Specialized Allez Gold ~ viewtopic.php?f=10&t=134419
wolfesquire
by wolfesquire
would look good with some Roval wheels
Birdman
by Birdman
My Campy mix is going on this bike. The black Campy kit should look awesome against the anodized gold frame :)
The rear brake cable routing is awful though... Of all the bikes that I've played with, this one generates the MOST rear brake friction... I gotta play with the housing length some more to resolve this issue. I'm pretty sure the cable housing entry/exit angle is the culprit.
wojchiech
by wojchiech
Birdman, have you tried nosed ferrules with your housing? They usually help resolve the friction points that are present at any given end of cable housing, especially if the entry/exit angles are not straight.
kalistar1983
by kalistar1983
what a fantastic color~!!!!
Birdman
by Birdman
@wojchiech, Thanks for the tip. I'll definitely try that.
Apparently this is a common issue per this thread:
viewtopic.php?f=3&t=131895
michel2
Location: somewere floating between here and the other side
by michel2
black and gold, john player special ! (-: loving it
is it a anodised or painted frame ?
Birdman
by Birdman
Anodized frame, painted fork.
The anodized gold looks sooooo awesome in person, especially under the sun. The painted fork however... not as pretty. BUT is full carbon so whatever.
Birdman
by Birdman
Some progress...
17 lb 01 oz = no pedal, no bar tape, with rear light, with bottle cage.
Ozrider
by Ozrider
That looks pretty awesome.
Black chain rings and removing the Bontrager wheel stickers would make the frame pop even more.
Parlee Z5, Trek Madone, Jonesman Custom
Ozrider - Western Australia
Birdman
by Birdman
Ozrider wrote:That looks pretty awesome.
Yeah I didn't think about the chainring color when I got those Praxis rings...
AZR3
by AZR3
Nothing a little spray paint can't fix :wink:
Birdman
by Birdman
Oh and by the way, I went full length rear brake cable housing. Drilled through the frame cable stops. Friction issue is MUCH improved.
Right now I'm just using regular shop bulk housing. Eventually will go to Yokozuna full length.
Birdman
by Birdman
mannequinforce
by mannequinforce
Was this bike ever updated or finished? Looking to revamp my allez this winter!
