Cervélo R3 2013
KAoslo
by KAoslo
PRL wrote:Long time lurker. About time to contribute.
Used to ride a Cervélo RS, but it got killed in a major crash last summer. Someone went down in the middle of the peloton at high speed, taking at least 15 of us with him.
While waiting for my scaphoid to heal I got this frame through crash replacement. I wasn't a fan of the black and blue 2014 paintjob, so I was very pleased when this frame showed up.
Matching shoes!
Frame: Cervelo R3 2013 size 54: 955g incl. Hanger
Fork: Cervelo FK30: 396g uncut (Because my right hand was in a cast I had the LBS put it together so didn't get a chance to weigh the fork after cut.
The fork on my RS lost 25g from cutting.)
Headset: FSA IS-3
Spacers: FSA Carbon 5mm x2: 2,5gx2=5g
Stem: 3T Team ARX 110mm: 129g
Handlebar: FSA SLK Compact Carbon 40cm: 218g
Bartape: Deda
Levers: Sram Force 22: 307g
Front Derailleur: Sram Force 22: 80g
Rear Derailleur: Sram Force 22: 168g
Brakes: Sram Red Aero Link: 258g
Brake Pads: Reynolds Cryo Blue
Crankset: Rotor 3D+ compact 170mm: 476g incl. spacer
Bottombracket: Sram Pressfit 30: 85g
Chainrings: Stronglight CT2 50: 104g
Chainrings: Stronglight CT2 36: 40g
Pedals: Look Keo 2Max Carbon: 248g
Cassette: Shimano Ultegra 6800 11-23: 212g
Chain: KMC X11SL
Wheels: Reynolds Assault SLG: 1540g
Rim Tape: Veloplugs Red: 3g per wheel
Tires: Continental GP4000s II 23mm: 219g
Tubes: Michelin Aircomp Ultra Light 60mm: 76g
Quickreleases: KCNC KQR Ti: 40g
Saddle: Selle Italia SLR Kit Carbonio: 129g
Seatpost: Ritchey Superlogic 27.2 300mm: 147g
Seatclamp: Cervelo R3: 16g
Gearcables: Sram Force 22
Brakecables: Sram Force 22
Bottlecages: Planet X: 22g each
Weight is 6,75kg as shown in the pics.
When I leave Sweden and ride real mountains in Spain, Italy, France, I switch to a DA C24 wheelset instead.
Weight with the DA C24 Wheels is 6,60kg
And last, a pic of my old RS, it weighed 6,6kg
Love your bike! Can I ask how tall you are in CM? I have just reserved a 2013 R3 in 54, but im wondering if the 51 is better. Im 175 cm tall.
PRL
by PRL
Sorry for the late reply. I'm 179cm and a bit of a long torso short legs build.
daveydoo
by daveydoo
Beautiful bike! I have the same frame but in the 105 colour scheme. I want to upgrade it into a racier machine and yours is pretty much exactly what I'm after. I want to upgrade the wheelset to some carbon hoops but there's not a lot of rear tire clearance on this bike and the non-drive side chain stay is wider than the other making even tighter. Do you know the width of your Reynolds? What tire size are you running? Have you had any clearance/rubbing issues?
I'm trying to figure out a decent carbon clincher that will work for my bike. Any thoughts would be much appreciated.
Thanks!
PRL
by PRL
The Reynolds Assault are 25mm wide and I run them with 23mm tyres.
Haven't tried anything wider so can't help you there.
PSM
by PSM
The Canon EF 135mm f/2L is the best lens ever made too.
FIJIGabe
by FIJIGabe
PSM wrote:The Canon EF 135mm f/2L is the best lens ever made too.
I'm partial to the 24-70 f/2.8 ;)
Beautiful build on both bikes.
PSM
by PSM
It's good too. But not like the 135. 8)
