It is currently Wed Jan 17, 2018 4:34 pm
Post new topic  Reply to topic  [ 33 posts ]  Go to page 1 2 3 Next
PostPosted: Fri Aug 14, 2015 8:18 pm
Here's my Scott Addict in Orica Greenedge colors. Complete build list will follow as some parts will be swapped in the short run. With Garmin + sensors (not pictured yet), it's a few gram under 6,4kg
After some longer rides, the steer tube will be cut with probably 5mm spacer under the stem instead of 10 mm now. Saddle is aready a very bit more horizontal, but was almost perfect as shown
Short term plans:
-Extralight ultrastar expander
-C260 stem
-Tune DC14 quickreleases instead of my old AC14's
-Decent bartape in white or black. What do you think? Current bartape was some old stuff laying around and used for the first initial rides, knowing that the shifters may have to be moved a bit to get it 100% perfect
Final weight will be around 6,35kg
For next year, plans are:
-Fulcrum racing carbon wheels
-Stages power meter
All suggestions are welcome :wink:
Current bikes:
Scott Addict Premium Disc 2018
Scott Addict Orica Greenedge 2015
Retired:
Canyon Endurace CF SLX 2016
Canyon Ultimate CF SLX 2013
PostPosted: Fri Aug 14, 2015 8:26 pm
Current build list:
Current bikes:
Retired:
PostPosted: Fri Aug 14, 2015 10:42 pm
Good looking Scott, by chance did you own a pre 2011 to compare?
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2015 Specialized SWorks Tarmac Da 9000
2016 Specialized SWorks Tarmac DA 9100
PostPosted: Fri Aug 14, 2015 10:44 pm
Very classy B&W Addict.
Congrats on the new ride.
Did it come from the bike store with Di2 or did you opt for it over mechanical? Just wondering.
5.7kg / 12.7lbs Addict SL w/PowerTap
9.3kg / 20.5lbs Scale 29 Pro ... woefully under-used
Retired: 5.9kg / 13lbs Addict R1 w/PowerTap ... lowest was 5.593kg / 12.33lbs
PostPosted: Sat Aug 15, 2015 8:52 am
Nope, but I've owned a CR1 sl (the very first ones, 890gr frameset) for almost 8 years. Loved that bike, although it was quite harsh to ride compared to my Canyon. This Addict rides .... like a Scott. Stable and firm, confidence inspiring. I think i'm gonna love this one, but has to be confirmed after some serious rides :wink:
Current bikes:
Retired:
PostPosted: Sat Aug 15, 2015 8:57 am
The deal was on a DI2 only frameset. No way I would have paid the full 2,8K € for the frameset. And I was temped to try di2 anyway, so, I went for it! Everything has been put together by myself, except the BB cups...
Current bikes:
Retired:
PostPosted: Sat Aug 15, 2015 10:42 pm
What's the verified weight on a scale? Any time I see a itemized spreadsheet I'm curious how well it matches reality.
PostPosted: Mon Aug 17, 2015 5:25 am
How does it compare to canyon ?
PostPosted: Mon Aug 17, 2015 8:01 am
Once the small updates are done, I will use my 5kg, 1gr precision kitchen scale to weight the bike minus wheels and the 2 complete wheels. On my luggage scale, I have 6435g at the moment, but that scale gives a verified 25 g more at 5 kg compared to the kitchen scale.
So generally, you should add 20 or 30 g to the spreadsheet weight to have real weights. You have +/-30 individual weightings, so 1 or 2 gr more or less per weighting, and you rapidly have some real differences at the end :( But a spreadsheet gives you a good idea what weight futur upgrade can save of add!
Current bikes:
Retired:
PostPosted: Mon Aug 24, 2015 10:52 am
After a short spin of 50 miles earlier last week and 2 serious rides this weekend (200 miles and almost 15000 feet climbing in total, avg 20,6 on both), I think i'm able to give a first review and comparison with the Canyon:
+ side:
* a lot stiffer, especially in the front. It's a joy to go out of the saddle with this. The canyon is far more slughish in that aspect.
* very snappy ride, accelarates very easely
* steering is stable just what it has to be, but remains very easy to handle. Even at > 50MPH on a less than perfect descent, steering remains calm. All good, far beter than the canyon (lacks stiffness in front and is far more twitchy). One handed riding is not a problem at all.
* Nothing to do with the frame, but DI2 is a pure joy, especially when you get tired at the end. With mech, you easely shift 2 cogs instead of 1 intended. With DI2, tap, and shift. Easy!
- side:
* a little harsh. Beter than my old CR1 SL, but far worse than the Canyon. Even with same wheels and tyres. I dropped a little pressure in the tyres, but no real improvement. I use a different saddle on both bikes, but that's no explanation : the front end of the Scott is also a lot firmer! In most review, testers talk about the real comfort of the new addict. Sorry, bu I don't get it. Now, in most reviws, they rave about the stiffness of the Canyon CF SlX. I don't get it either. The canyon is really flexy compared to the Addict (and the old CR1). Conclusion : take reviews with a real grain of salt!!
* Also nothing to do with the frame, but the DA brakes are not that impressive : fairly good modulation, but lack of real bite and stopping power. Even with my trusty Campy aloy wheels and standard DA blocks. It gets a little better as the blocks start to wear a little, but i'm a bit disapointed here. Arent' the DA brakes not the reference everything else is compared with?
Bottom line : The addict is a pure, hardcore racebike. The canyon is more of a granfondo bike, best suited for +5 hours rides without too brutal efforts out of the saddle.
More questions? Shoot!!
Current bikes:
Retired:
PostPosted: Mon Aug 24, 2015 10:57 am
Administrator
I like it too. The stem is a WCS 4-Axis not a C260. (At least pictured)
RESIDENT GRUMPY OLD MAN.
PostPosted: Mon Aug 24, 2015 12:38 pm
Indeed, a C260 one is on my shortlist :wink:
Current bikes:
Retired:
PostPosted: Mon Sep 14, 2015 9:52 am
First 1000 miles are in, and all I can say, is that, performance wise, this one is 1 step above my Canyon. Stiffer, snappier and more stable steering. A clear winner. Confort is still lacking a bit, even if I really feel at home on this bike. Di2 remains terrific and brakes, after proper pad setup and brake-in, finally work like the are supposed to be! White bar tape is nice, but a pain to keep clean...
Updates so far:
*5mm spacer under the stem instead of 10mm and slightly shorter steer tube
*Record cassette
*Tune DC14 skewers
*Saddle set up correctly
*Edge 520 (perfect visual match in B&W also)
According to my electronic kitchen scale, the bike without wheels is 4143gr and both wheels complete with everything are 2201gr. Grand total: 6344gr. Xls sheet gives me 5gr more, so pretty accurate :D Next step is the 6,3 kg barier 8)
Below a pic I took after the weekly cleaning.
Current bikes:
Retired:
PostPosted: Mon Sep 14, 2015 5:35 pm
Beautiful! loving that classic look! actually i own the exact same frame with ultegra di2...
only downside with my frame is that the screws for the bottle cage on the seattube are misaligned, so the cage points to the right side.
No big deal as Scott won't hesitate to change it to a 2016 addict...BUT, have you seen the New design? IMO the most boring and uninspiring paintjob i've ever seen for a team issue bike...not classic, not modern...just...aaah
PostPosted: Tue Sep 15, 2015 4:57 pm
Very nice :) Try a white saddle too
Scott CR1SL 6.25Kg | CAAD10 6.56Kg
There are no new unread posts for this topic. Scott Addict SL, size L, 999g frame + fork
mrlobber
Sun Nov 12, 2017 1:49 pm
mrlobber View the latest post
There are no new unread posts for this topic. Wanted: Scott Addict Team HMX frameset or bike in size L/56
in Wanted
cybernck
Mon Oct 16, 2017 10:44 pm
cybernck View the latest post
There are no new unread posts for this topic. FS: 3T Exploro Team Frame & Fork Size Large
Hubert
Sat Dec 09, 2017 5:06 pm
Hubert View the latest post
There are no new unread posts for this topic. I'm looking at buying a Scott Addict
dim
Fri Dec 01, 2017 5:15 am
TonyM View the latest post
There are no new unread posts for this topic. Scott Foil vs. Addict
DaVinci
29
6805
Wed Mar 01, 2017 6:31 pm
p3dalfaster View the latest post
Users browsing this forum: Baidu [Spider], Frankie - B, Global, godzuki26, KarlC and 15 guests
cron
