My Dream Evo Hi-Mod - Update 9-14-2018
Seatpost looks great. A longer stem would make for a better, more stable handling IMHO.
Trust me, I wish I could but then my arms would be too stretched out.
But it seems like you could easily move the saddle 1 - 1.5 cm forward.
kgt wrote:But it seems like you could easily move the saddle 1 - 1.5 cm forward.
You don't move your saddle to accommodate reach. I don't have long euro arms and legs. Wish I did because it would in fact LOOK better. I spent a long time setting my bike up to LOOK good and I paid for it. My bike is set up perfect for me now and I can feel the benefits. Wish I could run a longer stem, but it's too long.
I used Goof Off to get the logos off of my Superleggero post. It took about 5 minutes to finish removing both sides, but it's quite a bit stronger than acetone.
Bianchi10 wrote:kgt wrote:But it seems like you could easily move the saddle 1 - 1.5 cm forward.
With a longer stem reach would stay the same.
I would suggest moving the rider's body weight forward in order to have a better-more balanced handling.
kgt the most important thing to set up is the riders position relative to the cranks - as that will provide all the power. One does not compromise pedalling performance in order to look cool, unless you just ride to pose.
Setting the riders position relative to the cranks is important (is it set properly BTW?) but that alone does not make a right fit.
wow!!! very beautiful bike.... nice wheelset and frame...
- Resident master of GIF
- Contact:
lose the gold chain. sweet bike though
kgt wrote:Setting the riders position relative to the cranks is important (is it set properly BTW?) but that alone does not make a right fit.
Yes, I've been fitted a couple times. I have shorter arms so my reach does not allow me to be stretched out more that what I currently have without causing my arms to be too straight. My bike is set up perfectly for me right now. Most comfortable Ive been since I ever sat on a bike.
BmanX wrote:What brake pads were you using for the Enve Classic 45 clinchers?
Enve pads
Bianchi10 wrote:kgt wrote:Setting the riders position relative to the cranks is important (is it set properly BTW?) but that alone does not make a right fit.
Sorry I am insisting but you misunderstood me. What I am saying:
a. move saddle 1 cm forward b. get a 1 cm longer stem.
Fine position over the crankset, same reach, as comfortable, no more streched but that results in more weight forward = more balanced ride = better handling.
That's just my opinion. You may try.
kgt wrote:Bianchi10 wrote:kgt wrote:Setting the riders position relative to the cranks is important (is it set properly BTW?) but that alone does not make a right fit.
Ok I see what you are saying now. most likely, I still wont do anything as it has taken me a long time to get this comfortable. After swapping out my seatpost, it took me 5 or 6 rides to find my sweet spot again, even after taking measurements before making the swap and setting it back to what I had measured. I've always been very sensitive to minor changes. Not worth it for me considering everything is working well as of now. I may give it a thought in the future though. Thank you for taking the time to clarify your suggestion! Cheers
