Hi! Just sold my propel and bought this frame from a friend. Decided to make it an all arounder bike. So far its going pretty good specialy in the back area. So here is the specs of the build:
S works tarmac 52cm
Ultegra 6800 gruppo
Q rings inner and outer chain ring
Kcnc chain
Look keo blade 2 chromoly pedals
S works seatpost & clamp
Astute vt carbon saddle
3t arx team stem
Zipp ss sl drops
Supacaz bartape
Elite bottle cages
Chinese carbon 60mm tubular wheels with Continental gatorskin 25mm tubulars
Custom build wheel for climbing with veloflex 23mm
Total weight with carbon wheels, garmin sensor & barfly is 7.12 kg. And with climbing wheel approximately 6.8kg ish
any idea how to make it lighter without spending too much? Thank you
Sent from my LG-D802 using Tapatalk
S works tarmac sl4 need help
The Tarmacs always seem a little on the heavy side. I guess so do Colnagos and Pinas!
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
pradimtyo wrote:Hi! Just sold my propel and bought this frame from a friend. Decided to make it an all arounder bike. So far its going pretty good specialy in the back area. So here is the specs of the build:
S works tarmac 52cm
Ultegra 6800 gruppo
Kcnc chain
3t arx team stem
Zipp ss sl drops
Supacaz bartape
Elite bottle cages
Very nice!
