My $2k limit WW Project! [BUILD COMPLETE]
New stuff arriving and just working on ideas... Each pedal comes in at 1g over weight, while the cassette weighs 1g lighter than expected.
My Titanium Bike And Photo Blog
http://weightweenies.starbike.com/forum ... 5#p1246304
My $2k 12lb build Adventure!
viewtopic.php?f=10&t=133246&p=1151147#p1149264
jorisee01 wrote:What are you going to use as BB?
I got a FSA Road Pressfit 30 Bright bottom bracket with my FSA crank. It weighs in at 79g.
TOTAL # OF PARTS TO ASSEMBLE - 29
# OF PARTS NOW ASSEMBLED - 11 - PARTS REMAINING - 18
01. frame 845g
02. fork 340g
03. compression plug 26g
04. headset 64g
05. spacers 5g
06. stem 138g
07. calipers 184g
08. f derailleur 83g
09. r derailleur 169g
10. brake pads 30g
11. seat clamp 16g
WEIGHT OF CURRENT ASSEMBLY - 1900g
01. frame 845g
02. fork 340g
04. headset 64g
05. spacers 5g
06. stem 138g
07. calipers 184g
10. brake pads 30g
11. seat clamp 16g
subscribed
Some odds and ends.
CHAIN: I'm going to degrease the chain right out of the box and go with the Squirt dry lube from day 1.
TIRE SEALANT: I'm planning to insert this into the tubulars before riding as per recommended.
CARBON PASTE AND LOCTITE: Stuff I usually borrow from others
I've actually been using these for the past year. Normally I use 750ml bottles and these have never dropped a bottle - but that's on my S5 where my rides are up to 300km / 180mi long. Since this bike will be riding a maximum of 100km/60mi I've opted for smaller bottles, that fit in with the matt black/matte red/gloss black theme
The bottom bracket is FSA and came with the crank. It weighs 79g.
Ok the rear wheel with the cassette weighs in - as expected - at 717g
That puts the wheels set @ 1127g right now. Still waiting on skewers and tubulars.
PDK wrote:Can I get details on the wheels, like hubs/rims/price?
No problem. This is my 9th set of wheels - 4 of those are from China - for 5 bikes I have - 1 of those frames is from China.
Cost $500. Through Aliexpress.
Rims Type: 700C super light 24mm tubular rim UD matte F16h/R20h 20.5±0.3mm width
Material: 100% Carbon Toray T800,high TG resin
Brand: Carbon Braves
Used For: Road Bike / Track Bike
Rim Finish: UD matte (3K matte/glossy are available)
Hubs: Power Way R13 hub SMN cassette body(CPNL is available)
Spokes: black super light spokes (only 4g/ piece)
Nipples: black alloy
Recommended rider weight ≤130kg
Recommended spoke tension: ≤250kgf (Test at max 330kgf )
Recommended tyre pressure: tubular≤220psi,clincher≤120psi
Feature super light, stiff, carbon T800 material, basalt brake surface
weight 980±30g/pair
Warranty: 1 Year under normal working condition
Always nice to be surprised by a package you weren't expecting yet!
This is a 400mm post. I'll be removing about 100mm of this...
This is not the original saddle I was going to use... More on that in my next post.
