kevosinn's Cryptic Addict 4.64 kg
Very interesting build, I like it!
The paint stripping and attention to detail on the frame is impeccable. This has to be one of the top 'paint stripping' executions I've seen (and no one says it's easy).
The build itself checks all the uber-light checkboxes on WW with the aerolite pedals, cranks, housing, integrated seatpost, brakes, skewers, and the Red derailleur tuned to the max.
The Addict is a solid frame/fork combo so if the wheels are stiff enough and the pedals work for you and the shifting is quick and accurate - then this bike is top notch.
If it were me, I'd swap the Tune Skyline bottle cage for the traditional Tune version. I've tried the Skyline for maybe 2 rides and switched it immediately as it doesn't grip the bottles nearly as well (or causes bottles to get stuck). The traditional cage adds 2 grams perhaps, but I've only lost 4 bottles in 4 years and I ride off-road frequently, typically 2-10% of every ride. Perhaps the Skyline can be tuned with sandpaper or other fix, but the classic Tune cage functions perfectly without such hassles.
Thank you so much for the kind words!! I totally agree on the cage situation. This cage was 4 grams so maybe I'll keep it as the "show" cage lol. I have a regular tune one I'll throw on for sure.
I use skyline cage. I find if anything the bottle gets stuck and is impossible to pull out.
I put a little bit of tape in strategic points and it works very well.
You do have to use Tacx bottles.
Ok I think I came up with a solution for the cage. Going to try it here in the next day or so and report back. Will allow me to use any bottle.
thanks! The position is actually mild on this compared to my other bikes. Over the years I have always liked a slammed stem with a more aggressive position. I went out for 40 miles to shake it down yesterday and was extremely comfortable. Also I will say this may be the most comfortable seat shape ive ridden. Seems to fit me perfect.
Reason: deleted the quote. This is a reply.
Lots of respect to people who can take their time and build a bike like this... Your shifters look familiar... Did you have a blog about doing your shifters and the derailleurs? I have one bookmarked and I'm sure it's you.
Anyways - I'm bookmarking this thread too. Come winter time I want to shave 300g (To get it 4.9kg) and looking at your build I've identified how to do that on my bike... Thanks
My Titanium Bike And Photo Blog
http://weightweenies.starbike.com/forum ... 5#p1246304
My $2k 12lb build Adventure!
viewtopic.php?f=10&t=133246&p=1151147#p1149264
kevosinn wrote:Ok I think I came up with a solution for the cage. Going to try it here in the next day or so and report back. Will allow me to use any bottle.
I have an idea what you are going to do...I think. I wont say anything until I see.
Did you see my shifters from the front I took loads of material away ,,,not sure how far you went but mine work fine.
check them out here
Time for an updated build list I think
A few questions about razor stripping the frame....I have a BMC frame I'd like to do this to, and I've razored other parts (shifters, crank, etc.) so I have experience with those, but Im hesitant to start on the frame because, obviously, its structural integrity is much more important than my brake lever. So, that being said, I've always experienced a tiny bit of carbon being scraped, which is how you know you've removed all clear/paint. Is it safe to assume this is ok? Obviously you should stop there, and looking through this thread at your process it seems this was also your experience. Just looking for some tips before diving into this one. Thanks!
This is mindblowingly awesome. Love it!
Weight 74.4kg, FTP 303W => 4.04 W/kg
Retired Bikes
Custom 650B Kingdom Double9
Kinesis Aithein / Kinesis Racelight 4S
Current bikes
Reilly Spectre / Cervelo R3
Pivot Les / Pivot Mach4SL
Ventana El Conquistador
Retired Bikes
Current bikes
Yeah, not so much for weight savings, but aesthetics. I have an 09 team machine slt 01 and I'd like to see those carbon tubes rather than the red/white paint (which is chipping off anyways) which is so generic. I think I'm going to black out the aluminum lugs as well.....
wojchiech wrote:Ellingferd wrote: Just looking for some tips before diving into this one. Thanks!
me too, paint is so heavy seriously though, I don't know why more frames come just clear-coated bare carbon. Especially with carbon where the layup has unique distinct characteristics.
Totally love the raw, messy carbon layup lookLike what this Cervelo S5 looks like under the paint...
McGilli- I know what blog you're talking about. I think its called the climb. Thats not mine but ive read through that also.
Xena- Those look amazing with that whole build. I will be removing more soon for sure.
Derek- Updated the first post now
Ellingferd- With something this big you really start to get the hang of stripping all the paint and when to stop or keep going. I say to start out slow dragging the razor one way and go until you reach the carbon. It will look, feel and sound different once you reach the carbon. Once you are comfortable you can start dragging it both ways back and forth but dont try this until you are comfortable doing it quickly. It has to be done fast or it doesnt work well. Regarding the small bit of carbon dust you see I wont say its hurting it and as you go it will happen less and less as you get the hang of it.
