Cervelo R5 2013 - 6.06kg/13.4lb
Cervelo R5 2013 61cm
Carbonsports Lightweight GenIII wheels
Continental Gatorskin tubular 25mm
3T ARX team stem 110mm 6deg
Bontrager XXX bars 44cm
FSA SL-K seatpost 27.2 400mm 20mm offset (now 330mm Bontrager XXX 5mm offset)
SRAM Force 22 crank/S900 spider/Praxis 52/36/KCNC SL bolts
SRAM Red 22 chain
ROTOR PF30 BBright bottom bracket
Campagnolo SR 2014 shifters/FD/RD/11-29 cassette
Campagnolo steel cables/housing
K Edge braze on chain catcher
Shimano DA9000 brakes
Shimano DA7900 pedals
Arundel mandible cages
Fizik Arione CX carbon saddle w/ k:ium rails (now Fizik Arione 00)
Fizik superlight bar tape w/ carbon bar end plugs
ENVE Ti skewers
ww Sedluk helped me with this bike. It was a joint effort to make it light and fast and fun to ride. It's fun to work with other ww's to build fast bikes
Last edited by rideintospace on Sat Jul 25, 2015 10:26 pm, edited 2 times in total.
Nice! Another tall rider. I ride a 61 R3 and 63 CAAD/EVO.
Looks cool and a very nice weight. Props on the Lightweights.
Cicli Barco XCr Road
Moots VaMoots
Parlee Z1
SuperX Hi-Mod Disc
Moots VaMoots
Parlee Z1
SuperX Hi-Mod Disc
Wouldn't you be happy on the size smaller frame?
1415chris, the 61cm frame fits me perfectly. I am 6'4/193cm. The major change from my previous road bike ('05 61cm Bianchi Giro) is the 225mm head tube. The Giro is at 195mm, the 58cm R5 is 199mm. I like to ride centuries but they can get uncomfortable if the position isn't right for 5h. I haven't had a problem yet on this bike.
Doyler and Kumppa, I totally agree. It is a strange build list to be sure. The bike arrived with DA9000 and a very short rotor crank. I switched the crank for the 177.5mm SRAM, and like the campy shifting a little more than shimano. I'd prefer a more matched cockpit and group set, but this is working well. There are a couple of things I would like to change, like the saddle and up front gearing, before I try to match more parts
- Powerful Pete
- Moderator
- Location: Lima, Peru and the Washington DC area - it's complicated.
I like it. Good weight for a large frame (what is going on, are all the newbies on WW giants these days? ) and I always love bits o'Campagnolo on a Cervelo.
Supercommuter: Jamis Renegade...
Oldie but goodie: De Rosa Professional Slx, Campagnolo C-Record...
