Colnago C60 - RSWH build
Hi,
I have a new bike on the way.
Out of interest am calculating predicted weight based on components. I don't imagine I will get a great match however in trying to get list as accurate as possible (and learn a bit) I thought i would ask others what components I am missing.
Current list is as per below. Note I have obtained these weights for the parts proposed on the build to date.
Are cables etc included with the groupset weight or is that what I am missing? Am I perhaps just missing a bunch of grease? I doubt the predicted weight of ~6.6 kg as I have looked at several other C60 builds and weights don't come in that low generally I thought. especially with a relatively heavy saddle as i plan to have.
Frame size is 52S. colour scheme is RSWH. I'll provide photos as I can (built at the shop, not by me).
It is proposed to have black seat and bar tape - rest is white.
Bobo S&S Steel Bike - 7.5 kg
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR
To get it more accurate, you will have to increase the granularity, see the below from my Scott build thread
Cervelo S3 Disc - 6.78Kg/14.94Ib
Scott CR1 - 5.69Kg/12.54Ib
Scott Addict RC - 6.92Kg/15.25Ib
OnOne - Free Ranger - 8.68Kg/19.1Ib
ah. that is quite detailed. my favourite bit of detail might be "misc - air/talc/tape over valve hole - 18 g"
thanks for a lesson in how it should be done. my bike is being built by the LBS however this makes me want to take it all apart so i can weigh it right!
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR
bike yet to arrive but LBS say with 1 kg wheels on it (slightly less than what i'll end up with the Meilensteins) it is
my estimte was 6.619 (albeit with pedals) so comparable estimate is ~6.4 kg!
so a pretty good match. doesn't mean estimates were all perfect however as you do have a few things like grease and cables that are more or less and have covered over errors with estimates. (also fork that was trimmed).
anyhow with pedals it'll be around 6.7 kg for a 52S C60.
pretty enormous challenge to get it below 6 kgs. i think i'll focus on 14 lbs instead (6.35 kgs).
photos to come.
photos to come.
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR
haven't got the bike yet but the LBS has sent me photos of it built up. weight (sans pedals) is 6.5 kg. i absolutely welcome all thoughts. this is the first bike i've had built, all others bought second hand. i do really like the look of it so far though initially wondered if black seat post, bar and stem as well might have been the go. i've got a C59 so can't see that i'm in for any unpleasant shocks with ride quality and really looking forward to finding out how the lightweights feel versus the bora one's i currently use (albeit on the other bike).
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR
Colnago's done right are pure sex.
Exhibit A, above.
Exhibit A, above.
