Carbonic Canyon
Stolichnaya
by Stolichnaya
Canyon sells a compression plug, top cap and a flatter top bearing cover for those Acros headsets.
I think I got my nice red top cap that fits the 1 1/4 fork from Toronto Cycles.
But if you do not want to get lower, then just use what was supplied with the frame, it is a pretty good system. Lightest would be to use the lower bearing cover, tighten it all up with the Canyon compression plug and then remove the plug and use their open ring top cap.
metalplease
by metalplease
Hi livestrong - I was reading your project from the first page to here...Excellent Job on an alloy bike frame...impressive weight loss ! :) May try this on my 853 frame (not too fond of carbon...ssshhhhh !)
livestrong1986
by livestrong1986
metalplease wrote:Hi livestrong - I was reading your project from the first page to here...Excellent Job on an alloy bike frame...impressive weight loss ! :) May try this on my 853 frame (not too fond of carbon...ssshhhhh !)
thanks! :beerchug:
livestrong1986
by livestrong1986
Got some toys.
In web weight for chainring was about 125-130gr , but actually more!
livestrong1986
by livestrong1986
Some pictures.
Shaved off 153gr
nvroadie
by nvroadie
Very cool [emoji41]! We need pictures!!
nvroadie
by nvroadie
metalplease
by metalplease
Blimey ! - I didn't know what it was...until I scrolled down a bit further & saw that you'd 'dismembered' the brake/gear lever LOL - you guys really crawl inside your bikes is there anything that you won't drill/shave/remove ???
livestrong1986
by livestrong1986
Got some pre-owned in super good condition Mavic Ksyrium SR
6,26 kg
livestrong1986
by livestrong1986
Old rear Quick release from Mavic Ksyrium SL Premium 2008
And rear Quick release from Mavic Ksyrium SR
:noidea:
livestrong1986
by livestrong1986
On the way from Germany
Specialized S-Works Shallow-Bend Handlebar
Last edited by livestrong1986 on Fri Feb 17, 2017 7:22 pm, edited 1 time in total.
livestrong1986
by livestrong1986
Bought new pedals for 126 euro very good offer!
exustar eps-r carbon
and new Sram hoods.
livestrong1986
by livestrong1986
And new 120mm stem is on the way . 80mm Ritchey stem is too short . And 100mm Giant stem is too heavy. :D
I will get it tomorrow
livestrong1986
by livestrong1986
6,20kg
So , with Specialized S-Works handlebar it will be 6,14kg
