Scott Addict R1 Single Speed 3.39kg or 7.47lbs(FINISHED pg6)
BRZeer
by BRZeer
DuMa that is goot look bike. I can ride dat bike faster in my country Vietnam!
jekyll man
by jekyll man
Love the finish on the frame!
Awesome :)
Official cafe stop tester
Dynamo00
by Dynamo00
Sick Scott Addict SS, can't wait to see you finish your next project.
BmanX
by BmanX
Have you finished this?
BIG DADDY B FLOW
AERO & LIGHT is RIGHT for 2 decades
godzuki26
by godzuki26
Hello,
@BManX, I did finish the bike. I went with the THM Scapula F and the schmolke MTB bar. It looks like a commuter bike. I was waiting for a Fibrelyte 44 tooth light version chainring to drop 40 to 50 grams on the 95 gram 49 tooth Aero chainring I have on there now. I was also going to post pictures after I got my Canon Digital camera for Xmas.....well I got a couple Old Navy Sweaters instead of the camera so I will post final build pics with my iPhone once I get some time.
Thanks :beerchug:
:arrow: BH Ultralight
:arrow: Litespeed Ghisallo
ImageCannondale Evo HiMod
ImageFelt AR FRD
BmanX
by BmanX
Awesome but sorry about the sweaters. I am thinking of new frame and building a new 1 X 10 build but want to get the new Sram eTap first so I can take the old sram and place it on the new build. In the mean time, I might do the build but do flat bar commuter bike set up.
BIG DADDY B FLOW
victorduraace
by victorduraace
Full build pics please!!!
Broady
by Broady
Awesome build, I did a similar thing with my old Storck, albeit nowhere near as pimped!
Dynamo00
by Dynamo00
Any pics yet? ;)
godzuki26
by godzuki26
Wow I love the Stork. My finished build looks very similar. I like the simplicity. I showed up to a 30mph paceline ride on mine and the bike felt the same as it did before I had it repaired. I can actually still get very low and somewhat aero with the mtb straight bars by grasping close to the stem and keeping my elbows in. l got a lot of "what is that?" questions.
Sorry about the pics. I will post them this weekend.
ImageFelt AR FRD
DavidG
by DavidG
Did you ever finish this amazing Scott Addict singlespeed build? I would love to see photos and a final build list with weights.
Based on the components you've shown so far in this thread, by my calculations the bike should be sitting at a tad under 7.6lbs... But please correct me if I'm wrong.
Cheers.
David
godzuki26
by godzuki26
I apologize about not posting updated pics. I have been very busy at work. I have also been obsessing over Magnesium clincher rims that I have been playing around with.
I really enjoy having this Scott Single Speed bike. It is stealth and matches all my other bikes in my garage. No brand name "in your face" type of logos is what I prefer on all my bikes. When initially building this frame, I wanted it to be under 7 lbs. I missed it by .47 lbs or 213 grams. If I were to do this build all over again, I would have asked Spyder Composites to remove the rear brake cable stops on the top tube (since I am not using them on this build) as well as remove the water bottle bosses on both the seat tube and the down tube for a much cleaner look. I could have saved another 50 grams on the Fibrelyte 49 tooth chainring that I had built extra thick for stiffness. I also do not like the barrel adjuster for the THM fork. I was unsuccessful installing the brakes without using this eye sore of a part. It is a pig part as well weighing 7 grams. I aborted the standard drop bar track setup because this bike was a little too flashy for the velodrome. Showing up with a DASH disc wheel was over kill and received too much attention.
FRAME: 2009 Scott Addict R1 modified with Paragon titanium track dropouts 782 grams
HEADSET: Extralite Scalhead 51 grams
TOPCAP: Veloflyte 1 gram
TOPCAP BOLT: Schmolke carbon M6 1 gram
HEADTUBE SPACER: Extralite Delrin 1.5 gram
STEM: Ax Lightness Zeus mountain 67 grams
HANDLEBAR: Schmolke TLO 25.4mm 72 grams
GRIPS: Extralite foam 11 grams
BRAKE LEVER: KCNC VB1 27 grams
FORK: THM Scapula F with integrated brake 310 grams
BRAKE HOUSING: Aican Bungarus 14 grams
BRAKE CABLE: KCNC titanium 3 grams
PADS: Swissstop Black Prince 15 grams
SADDLE: DASH P3 40 grams
SEAT TOPPER: Tune Cappy with carbon cradle 67 grams
CRANKSET: Ax Lightness Morpheus 346 grams
BOTTOM BRAKET: Ax Lightness BSA 68mm 79 grams
CHAINRING: Fibrelyte 49 tooth single speed (built extra thick) 95 grams
BASHRING: Fibrelyte inner bashring (to support the carbon spyder) 11 grams
CHAINRING BOLTS: KCNC SL 8 grams
PEDALS: Ultralite Cirrus Ti 73 grams
CHAIN: KMC X11DL DLC black
COG: Absolute Black 17 tooth 23 grams
LOCKRING: Tune 3 grams
COG SPACERS: Q2 Avery spacer kit 8 grams
WHEELSET: Custom front 323 grams Custom rear 437 grams
RIMS: 77 Composites 25mm tubular
HUB (FRONT): Extralite CyberHub 20H
HUB (REAR): Extralite CyberHub 24H
SPOKES (FRONT): 20x Sapim CxRay Superspokes
SPOKES (REAR): 12x Sapim CxRay Superspokes and 12x Sapim CxRay on driveside
TIRES: TUFO Elite Jet<160
SKEWER: Tune Skyline time trial 18 grams
ImageFelt AR FRD
godzuki26
by godzuki26
ImageFelt AR FRD
Bely
by Bely
[emoji122]this is awesome
Current
Festka Scala | Pego Respo | English V3 | Colnago EPS Erik Zabel | Colnago V4rs
Incoming
prendrefeu
by prendrefeu
