S-Works Allez
danielklaus
by danielklaus
Guys, I am Planning to buy a S-Works Allez and I would like to get away from cable running onthe frame and hide them inside. Is this possibile or I have to do it with Di2?
I plan SramRed 22, maybe the Wireless groupset will come out and I have my problems solved. :D
Pottsy
by Pottsy
Why get rid of one of the best things about the Allez?
Internal cables only make the appearance of the bike cleaner.
You will only be able to run Di2 internally & will have to drill the frame. Unless you get the complete bike with Di2 on it.
danielklaus
by danielklaus
Pottsy wrote:Why get rid of one of the best things about the Allez?
What do you mean get rid of the best things about Allez?
The Di2 Frameset only is not Di2 ready.
regards,
Daniel.
Ashepp
by Ashepp
The S works Allez is only available with external mechanical cables or internal cables for Di2. I know this because I own one. If you want this frame and you want internal cables, Di2 is your only option. I hope this helps.
danielklaus
by danielklaus
Ashepp wrote:The S works Allez is only available with external mechanical cables or internal cables for Di2. I know this because I own one. If you want this frame and you want internal cables, Di2 is your only option. I hope this helps.
Yes but the Di2 is only available as a whole bike not as a Frameset. I am After the Silver Ano/White Frameset.
