BMC Teammachine SLR01 build thread
djm
by djm
Preliminary build list.. Updated May 8
2013 BMC Teammachine SLR01 Di2 frameset, 57 - bought unused in a very pleasant deal off this forum! :-)
Selle Italia Kit Carbonio Flow saddle
DA9000 brakes
Ultegra 6700 crankset
PRO Vibe S7 130mm -10 degree stem, no decals
Shimano brake wires, housings
Shimano 6870 Ultegra Di2 groupset with internal battery
Ritchey Evocurve aluminium bars, no decals
Shimano DA9000 C24 CL wheelset (still waiting for it, RS81 due for warranty replacement in the mean time)
Specialized Roubaix swrap bartape
Bottle cages; Elite Custom Race, unhappy with them, will wait for a decent offer on Mandibles or just cash out for King Cage ti and get it over with)
Feel free to make suggestions on components to use or not to use.
I decided to go with the internal battery as that is much cleaner than the under down tube position. However the seatpost on this frameset isn't adapted for that, and I decided to cover the battery in foam and then "screw" the battery into the post. I fixed the foam with some duct tape, then rolled it around the entire battery, finished off the ends with some duct tape to facilitate an easier entry into the post and frame, preventing the foam from being snagged on some rough carbon pieces inside the post.
I tried pulling out the battery to see how well it was sticking. The battery came out with a loud pop and required quite a lot of pulling. Now I just hope that the foam will not compress much over time, but I don't think it will. At the current state of friction other parts of the bike will go before this battery down into the seat tube, even if wet.
Fitting the Di2 wires was pretty straight forward and not more difficult than regular wires. Despite having had three bikes with Di2 this was my first time threading the wires through the frame holes. I used a couple of old brake wires and then attached the cable heads with duct tape to the wire, and pulled it back and through the frame openings. Zip tied the Di2 junction box to the underside of the Barfly 2.0, so that I can settle with slightly shorter cables on the bars and keep the stem clutter free.
Also the frame required oval grommets for the Di2 wires, man were they tricky to snap into place. It did however get easier once lubed with some silicone.
Junction box zip tied to Barfly 2.0.
dereksmalls
by dereksmalls
Nice
djm
by djm
Getting somewhere :-)
Current weight, as pictured 7.00 kgs.
KarlC
by KarlC
Wow, now that's a drop lol.
You should ezaly be able to get below 7 kgs I'm not far above that with my heavy TMR01 and deep carbon wheels.
C64 My Sixty 4 SR EPS 12
djm
by djm
KarlC wrote:Wow, now that's a drop lol.
Yeah, seat post in position now, a fair bit of drop but not extreme, I believe around 12-13 cm, which is where I'm comfortable.
I'll shoot some better photos in daylight.
With my Mavic CCUs the bike should be quite a lot lighter. Approximately 500 grams on the wheelset, and I presume the tubular tires are a bit lighter than the clinchers with their butyl tubes.
djm
by djm
Raineman
by Raineman
That looks fantastic, love the look of the stem without decals.
ak47
by ak47
I am planning to remove logos from my Vibe 7s stem as well. Have you used acetone or something else?
djm
by djm
Thank you Raineman! ak47, acetone. Part of the paint was a little thick, but everything came off in five minutes.
rOYk
by rOYk
I love it!
HanSolPark
by HanSolPark
SLR01 is really nice machine! It's light but well-set. My slr01 is about 6.8kg with Bora One 35.
djm
by djm
New picture! :-)
djm
by djm
6,96 kgs with pedals and race wheels.
BlackMadone
by BlackMadone
That drop is incredible!
nobuseri
by nobuseri
Clean ride. If I slammed my stem, my drop would look like yours.
Nicely done!
Cicli Barco XCr Road
Moots VaMoots
Parlee Z1
SuperX Hi-Mod Disc
